F150 motor problems PLEASE HELP
1994 F150 302 idles fine in park. Once put into gear the engine shakes and there is no power. Is also backfiring through the throddle body. Please help if you can, my brother has to report for duty on the 6th and needs to drive this truck. Any ideas would be greatly appreciated. Thanks
My dad put an F250 302 engine in the truck. The manual says to use the firing order 13726548, but I have seen the order 15426378 being used. But this second order was supposed to be used on engines prior to '93. So in the morning my dad is going to check the second order. He also took off the tps and it was covered in oil. So he's going to replace that too.
on
