Bad Coil Pack? 1999 5.4L
The other day when I started my truck it was running like crapola and acted like it was not gonna get me anywhere. I went to the local AutoZone and they pulled code P0301 which says there is a "misfire" on cylinder #1. The next couple of days the truck drove fine. Yesterday the same problem - seems intermitant. I "had" my spark plugs changed about 120K and we are not about 136K so I do not think it's the plugs. I know there are are SEVERAL threads devoted to coil pack replacement but I have not read one relating to a 1999 5.4 specifically. Where is #1 located on this year model and any other help or steps would be GREATLY appreciated. Since the rooked my on the plug replacement for my own self esteem I want to replace this myself.
Thanks in advance !!!!
TommyRox
TommyRox
First of all you don't have coil pacs, you have COP's (coil on plugs) there different.
You lucked out - #1 is the easiest to replace - it's the first one on the passenger side - 10 minute job . Just remove the 7mm bolt and pull the coil off the plug in a twisting motion. Apply dielectric grease inside the boot and at the joints - bolt the new one in place. done.
I believe that #1 is the front passenger side cylinder. You are lucky that it is easy to get to. I started changing my plugs and this plug was full of oil. Just remove the bolt connected to the injector base and it should come right out. If you have a multimeter you can do some resistance checks on it.
You don't need to check it , you know it's bad . Besides resistant checks (primary-secondary) usually pass and they don't mean anything. Cop's don't fail here , they fail under a load and the only way to check is at the dealership on there computer in mode 6 that gives you cylinder history readings. Just do what I said and you'll be ok.
Yeah I just got off of the phone with Ford - $88.04 or I can do this:
http://item.express.ebay.com/Vehicle...mdZExpressItem
Do you just wait for the SES light to come on to know if your COP is bad or is there a way to see if a COP is not doing its job very well?
Originally Posted by DHoot
Jbrew,
#8 just went bad on me this week after my fuel supply line severed and it covered the COP with fuel .
What usually happens - (I have 200,000 miles so I've went thru this a few times) You'll start to misfire and won't realize it until it worstens and then you finally get a light when it goes totally out.
#8 was bad and I didn't have a light!!
What I did this time and other times in the past , I force a light. When it's misfireing I just give it hell , I'll step on it - floor it , work it hard until the light starts to flash . It's the only way to wake the computer up , unless you have access to a dealerships computer and look at graphed history to pinpoint the weak cylider. Your comp always stores history.
Originally Posted by TommyRox
Awesome - glad to support members !! I just bought 2
LOL - Kev's not a member - I know him because I purchased COP's for others from him . So have other people here. I got to know him because he sold COP kits and still does. The kits come with plugs , he always sends the wrong plugs. (bonehead) so I have to call him and specify the plugs every time . Still a good deal tho.
