crane powermax 2021 camshaft ??
Lobe separation doesn't tell you anything about how rough the idle will be (lope). Look at the specs on these two wildly different cams....
Duration 252/252
Lift 433/433
Lobe Separation 110
Duration 294/306
Lift 554/558
Lobe Separation 110
The first cam will run a smooth, stock-like idle in a 302. But the second, well, it will lope its damn a$$ off! But, if you noticed, the lobe separation is the same.
So why don't you post the rest of the specs? Crane's site seems down right now or I would look it up myself.
Duration 252/252
Lift 433/433
Lobe Separation 110
Duration 294/306
Lift 554/558
Lobe Separation 110
Hydraulic flat tappet
Basic Operating RPM Range: 1,000-4,000 RPM
Intake Duration at 050 inch Lift: 190
Exhaust Duration at 050 inch Lift: 198
Duration at 050 inch Lift: 190 int./198 exh.
Advertised Intake Duration: 252
Advertised Exhaust Duration: 260
Advertised Duration: 252 int./260 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.416 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.432 in.
Valve Lift with Factory Rocker Arm Ratio: 0.416 int./0.432 exh. lift
Lobe Separation (degrees): 109
thanks bro.
thanks bro.
