weird smell????
weird smell????
i have this weird smell coming from the rear drivers side around the tire. i first thought it was the brakes. i put new brakes on the smell is still there. i have 3 week old exhaust. It smells like a burnt smell, like it could be the brakes but i dont think it is. any ideas?
Have your emergency brakes checked. Some have a problem with rubbing and overheating. This also caused a vibration. In my case, just backing off the adjustment a little bit fixed the problem. They adjust just like any other drum brake. Mine were tight from the start and for whatever reason, would at times rub and cause the vibration, heat, and smell.
but if this was the case wouldnt it do the same thing on the passenger side? bc the smell only comes from the driverside.
Originally Posted by ssjt1
how easy is a piston seal to fix and what it cost?
Its easier and cheaper to get new calipers then to have it rebuilt.
http://cgi.ebay.com/ebaymotors/NEW-B...spagenameZWDVW
