Bleeding Power Steering
Usually this is not much of a problem but there are exceptions.
Another way is make up an air tight rubber/cork or whatever plug assembly with thru pipe, to push in the top of the reservior and using a hand vacuum pump to draw a vacuum.
With the engine running , this takes the air out of the fluid in a hurry.
