o2 sensors
o2 sensors
I just got a "check engine light on". So then i went to my buddy and he scanned it and we determined that the o2 sensors on the right side bank are going bad. I was just wanting to know about how much they will run for 2x of them? Also would you just replace all 4 or just the one's that are bad? Thxs
Originally Posted by jsalty
My service engine soon light is on also.
I have codes
P0171 and P0174
Sysetm too lean Bank1 and Bank2
I replaced the Vacum elbow with some fuel line (is that a good idea?) it was cracked. My light is still on.
I have codes
P0171 and P0174
edit: i believe this is how its done
KAM reset: disconnect negative battery cable and touch it to the positive battery post. then reattach
I'll bet it's not the 02's as well - seeing how you got those codes - hell ,that tells me your 02's are working fine.
Since you already fixed the vac leak, I would clean the MAF and then reset, that's the procedure - in most cases , you'll be set.
