2001 f150 supercrew plugs
Old 12-16-2006, 10:40 AM
scalls's Avatar
Anybody tell me how to get to my sparkplugs? I can't seem to see them. #2 misfiring and going to change them all out. thanks
Old 12-16-2006, 10:42 AM
lenore's Avatar
Go to technical articles tab on this site, there is a spark plug changing thread.
Old 12-16-2006, 01:30 PM
atsioukl's Avatar
your plugs are concealed underneath a COP (Coil-On-Plug) ingnition coil. They are round and balck in color and have a wire harness plugged into each. There are 8 of them - one on each plug. To remove the COP, disconnect the harness and unscrew the gold screw holding it down. I beleive the screw is an 8 mm. Once you unscrew the screw, pull up on the COP. You should get the entire assembly (Coil and boot) out. If the boot remains in the hole, use a pair of pliers to grab hold of it and pull it out.
Your plugs will be recessed deep within the holes that the COP's were in. You'll need a long extension to reach them.
All but the 2 rear most plugs are pretty simple to replace. The 2 rears require a little manuevering.
Good Luck!
Old 12-16-2006, 02:23 PM
bullseye670's Avatar
Its actually a 7mm bolt. You will most likely need to remove a few small things to get at them. DO read up on this before doing the plug change.
There are a lot of little tips to know.
Don't forget the dielectric grease. Buy the big tube.
I always unplug the injectors to get a little more room at the plug/boot area.
bullseye670..................
Old 12-16-2006, 02:26 PM
tritonpwr's Avatar
Search
This topic has been covered many, many, MANY times.
Old 12-16-2006, 06:00 PM
PONY_DRIVER's Avatar
7mm botls hold each COP in place. I suggest using a 1/4" wratchet with extensions to reach them. I find that I tend to overtorque small bolts when using a 3/8" wratchet. Pull each COP and use compressed air to clean each plug-well BEFORE removing the plugs!
You will need to remove a small bracket on the drivers side to get to #5 and possibly #6, it goes from the top of the T-stat housing to the PS reservoir. Those bolts are 8mm or 9/32. I've used both sized socets to remove that piece (don't ask).
Old 12-16-2006, 06:03 PM
built54's Avatar
also the fuel rail on the drivers side needs to be moved a little, i worked around the pwr steering reservoir bracket
Quick Reply: 2001 f150 supercrew plugs
