I know about so many brands of oil but what is BEST?
Originally Posted by BlueOvalFitter
Motorcraft,sold at Wal-Mart for $2.32 a quart.It is a synthetic blend and by far,IMO,the best synthetic blend out there.And,the lowest priced too! BTW,your truck should use 5W30.
Oh,I recommend using Motorcraft oil filters.Wal-Mart sells them also.
5w-30 comes as either dino or a full synthetic.
EDIT:
SAE 5W-30 and SAE 10W-30 Super Premium Motor Oil
Meet the requirements for the American Petroleum Institute(API) "Engine Oil Licensing and Certification System." Both 5W-30 and 10W-30 carry the API "Certification Trademark" identifying them as meeting the latest performance standard for gasoline engine oils established by the vehicle
- Fuel-efficient formulas include special friction modifiers that save gas
- Premium additive packages fight sludge, varnish, rust, corrosion and wear
- Formulated for easy cold-weather starting–at temperatures down to -10 degrees Fahrenheit (-23 degrees Celsius) with 5W-30 and 0 degrees Fahrenheit (-18 degrees Celsius) with 10W-30
- Both oils meet vehicle manufacturers' performance requirements for gasoline engines
- 5W-30 is recommended to service any gasoline-powered passenger car or light duty truck engine prior to 2001 model year
SAE 5W-30 Full Synthetic Motor Oil
New Motorcraft® Full Synthetic SAE 5W-30 Motor Oil is designed, engineered and recommended by Ford Motor Company. It meets or exceeds engine oil recommendations by Ford Motor Company and many other equipment manufacturers that recommend oils of this viscosity grade and quality. It is also certified by the American Petroleum Institute (API), and bears their "Certification Trademark." Other benefits:
- Improved cold-temperature performance
- Lower volatility for reduced oil consumption
- Reduced engine wear
- Increased protection in severe operating conditions
- Formulated for fuel efficiency
if you want the best then get the Full synthetic.
Originally Posted by UberDude
the only synthetic blend Motorcraft makes is the 5w-20
EDIT:
EDIT:
on
It don't matter. Use an oil with the latest API rating, I think it's SL now. Use the proper weight for your engine. Use a good filter, I strongly recommended Motorcraft. Change your oil and filter regularly (along with other basic maintenance things, fluids and filters, etc.), and quit thinking so hard about oil.
Originally Posted by Narvous
Worng i have some hear it is Motorcaft blend 5w30
Oils
SAE 5W-20 Premium Synthetic Blend Motor Oil
SAE 5W-30 Super Premium Motor Oil
SAE 15W-40 Super Duty Diesel Motor Oil
SAE 10W-30 Super Duty Diesel Motor Oil
SAE 10W-30 Super Duty Motor Oil
SAE 10W-30 Premium Motor Oil
SAE 10W-40 Premium Motor Oil
I've got 6 quarts of Motorcraft 5W30 sitting in a Wal-Mart bag on my tool shelf,which reads on the back of the bottle "synthetic blend"!
Um,Uber,you think Motorcraft slipped some 5W20 into my 5W30 bottles and misprinted the back of the bottle?
Sorry,but Motorcraft 5W30 "AND" 10W30 are synthetic blends! And,can you guess who makes this oil? CONOCO!!!!!!!
I used Castrol 50/50 for about 198,000 miles - always used motocraft and wix filters - 200,000 + and running Amsoil 100% syn now . I think it's the best , if not - I want to know. Also I've read I don't have to change until 7500. So I figured 5000 miles I 'll change it out to be safe. Great compression , no leaks and it does't burn any at all within 3000 miles.
I have a 98 5.4L tho.
Miles speak for themselves , just burn the quality stuff..
Originally Posted by chester8420
Forget oil. How you drive is what determines how long your engine will last. If you beat it all the time, and don't let it warm up on cold days, you'll tear it up quicker than somembody that treats theirs right.
Originally Posted by KDOTengineer
