Is Motorcraft Synthetic Blend 5-20 good for first oil change?
yeah i did a search but couldnt find a solid answer. I ask cause its the only motorcraft oil available in my town and ive heard people say that i should only use regular oil for the first 5K miles :o
assuming your in an 06 F-150 or something with an oil filler cap that says 5w-20 i'd say this..
YES, IT IS ALREADY IN YOUR ENGINE FROM THE FACTORY.. for a reason
here ya go.. .
SAE 5W-20 Premium Synthetic Blend Motor Oil
Introducing Motorcraft® 5W-20, the motor oil that’s better for new Ford, Lincoln and Mercury vehicles and less harmful to the environment. Designed, engineered and recommended by Ford Motor Company, it delivers performance comparable to our Motorcraft® full synthetic at both very high and very low operating temperatures and pollutes less.
Motorcraft® 5W-20 motor oil dramatically outperforms and outprotects conventional motor oils. It meets the stringent WSS-M2C153-H Ford Motor Company specification to give the balance of engine durability and performance and to maximize fuel economy while reducing emissions. Due to its low volatility, low oil consumption is maintained. What this means for the environment is a motor oil that pollutes less.
and while your at it hit this site up
http://www.motorcraft.com/products.do?item=15
here ya go.. .
