Engine is showing its Ford traits
Well, :sigh:... Engine is leaking oil something fierce, looks like the pan gasket and/or rear main seal. Also it looks like it is coming down from atop the engine in the back agaisnt the firewall. Any idea of where this is comming from? Also, the lines from the remote oil filter are always covered in oil. Is it common that these lines leak? Now for the coolant part. I seen a lil puddle on the side of the block next to a freeze plug. Ofcourse its the plug right in front of the engine mount. How do you go about changing that? Have to lift the engine? Its a tight spot.
thanks
thanks
Chevy
Originally Posted by Camarothatcould
Yes, its coming down from above the starter side. Is it a potential sign of danger? Or should I leave it alone?
on
thanks
thanks
If you have the engine out, and it's like the '92 do the sump gasket too, mine leaked like anything - you could actually see where I'd driven, it dripped so much. I have a small leak in the front seal but apparently they're easy to do.
You should also do the front and rear seals, regardless if it's out of the truck, they'll need doing sooner or later....
There might be a dye you can add to the oil to help you localise the leak.
I had read about your oil lines on another thread, thats why I brought them up. This truck is the only thing I have for the winter, so until I have my Camaro up for the summer, I cant do anything major to it. Yes I run the right weight oil and no there is no sign of mixing fluids at all, and I know it has been leaking for a long time since the gunk build up was tremendous around the rear of pan. Thing has 151,000 miles on it, so If I were to pull the engine and redo all the seals, I would rather get a Windsor goin instead of doing hundreds of dollars worth of gaskets and junk and only have the engine last a few more years...
on
[QUOTE=REBSR76]I see your a chevy guy. Lets start from the begining. Did you put the caps on? Two, don't put any "chevy in a can on it" AKA, Bondo also black pepper won't work, and neither will stop leak. Now that all you GM fixits are out of the way, QUOTE]
You have to use strange and crazy ideas such as these to fix a Chevy, because its strange and crazy for something to go wrong with it. I have owned three Fords now and this will prolly be my last. Nothing serious wrong with it, but stuff that has never went wrong with my good ole bowties!
Good thread! I'm a young ford owner, excluding the old farm truck(thats still running great), I have been reading my *** off to get aquainted with the ford problems. Chevy has its own set of problems that are different than Ford for sure. I had to come to terms with how I felt about the big switch. I have worked in the automotive industry for 15 years now. I'm comfortable with most Chevy designs and their flaws. Ford on the other hand uses so many things different that I need to rethink a lot. Overall Ford trucks seem to hold up better but both do well. I noticed "the tick" coment. Would someone expound on that please? Is that the 5.4 sounds like a quiet deisel at idle tick? I read and was told about the TSB reguarding the timing chain guide/tensioner replacement to solve this. Same thing? anyone done just that? I have learned long ago to use 5w20 for sure and do so. didnt change noise or anything. Runs good but gas milage is 12.6-12.9 over all. 4x4 and screw doesnt help I know lol. T
