E- Fans
How are you using the truck. If you go off road through deep water y ou need to hook up a power disconnect so the fans will not try to run in water. If you run on the street and do not "work" the truck a thermosta only with an AC on swich may be all you need.
I use my truck primarly as a commuter during bad weather. For my efan hookup I have the passender side hooked to the AC and it is set as the 5 degrees lower than the driver side fan. The driver side fan is wired with a manual override so I can turn the fan on at any time. I also have a relay set up with a switch so I can disable them if I need to. I am using the Troyer fan setup. I have had one controller fail closed so it stays on all of the time - now that cooler weather has set in I have diabled it. E-fans are nice to have but they can have issues. BTW: I have had thes for about 5 years.
