Poor coolant flow at idle
I am experiencing a very strange problem with my 1997 F-150 4.6L. When idling I lose heat, temp gauge looks fine, no sign of overheat. When I rev the engine higher, the gauge swings up to the high side for a couple seconds and then back to normal.
This is clearly a flow problem but I am wondering if it is the radiator or could a water pump possibly have weak performance. The reason I am wondering is that the truck won't overheat with some rev's and standing still. I would think if it was a plugged rad it would still overheat. Has anyone ever had a water pump go bad but not leak?
BTW-coolant flushed this summer and belt change, new t-stat, 112,000 miles, no coolant contamination or oil contamination.
was it a complete flush?? block ,heater core etc...grab the fan blade see if you can move it up and down. if you can pump is going. so its fine when driving around? heats fine, temp etc..???. a pump can go bad with no apparent leaks, the fins inside wear out. so doesnt pump as well. that is a rare though. you have 112k? thats not high miles for these trucks.i have 2 4.6s crown vic,f150both over 120k still om original pump,keep fingers crossed
Yes everything is normal unless the engine idles, doesn't have a problemm when sitting still when revved to 2000, checked the tensioner and belt, tight, no play in the water pump or fan, clutch fan is spinning, I am going to have the radiator tested, maybe the pump is having a tough time pushing coolant at low revs. May also replace pump both to rule it out and because it does have a lot of miles on it.
