oil consumption 4.6L
Old 11-17-2006, 10:49 AM
barry1me's Avatar
I have a 97 F150 with a 4.6L 140K runs great, but uses oil. When I bought the truck the guy told me it used some oil, but I am using about a quart every 1000-1500 miles. He told me it mostly burned oil at start up. I noticed this a few times once I first got it, but since then I havent ever noticed it at start up. Any ideas on what could be wrong?
Old 11-17-2006, 11:48 AM
masseyman's Avatar
not bad
In my opinion that is not bad at all, in my experience I would call that perfectly normal. I'm sure others will have a different opinion.
Old 11-17-2006, 11:57 AM
akheloce's Avatar
^^^ True, I have a different opinion... 162,000 and not a drop used per oil change. Have you noticed smoke in exhaust? Do you see a leak? I have a remote filter under the bumper that had a compression fitting leaking because it was loose (about 4 years ago)... tightened it up and no probs since. If you have ruled everything else out, I would try a leak down test to see what kind of compression you have.
Old 11-17-2006, 12:45 PM
GIJoeCam's Avatar
The simple fact is that some engines consume oil, others don't. My truck consumes oil sometimes, and not other times. I have yet to find the rhyme and reason to it.
Ford's official spec for excessive oil consumption is 1 quart in 900 miles. Anything less than that is, in fact, considered normal. If you went through 5 quarts in 5000 miles, it'd still be considered OK by Ford's specs.
-Joe
Old 11-17-2006, 02:23 PM
keith97xlt's Avatar
-Joe
i have a 97 4.6 125k.not a drop of oil burned between changes. maybye you have really worn rings. all depends how previous owner treated her
Old 11-21-2006, 11:08 AM
barry1me's Avatar
Thats what I have been told. The truck runs great, decent mileage, and ok power, I was just suprised I guess that it burns oil. From my experience with 4.6's is there about bulittproof. I had a friend drive it the other day and put the accelerator to the floor at 30-60 and I was behind him and I didnt notice any smoke or smells. When I originally bought it from the PO he said it uses a little bit of oil and he said it does it when it starts up. I noticed this for a while when I bought it now I dont notice it any more
Old 11-21-2006, 11:38 AM
Bent6's Avatar
My truck uses a similar amount of oil and has for the last 150,000 miles with 0 ill effects. The truck currently has 305,000 miles on it. I've added well over 100 quarts of oil between oil changes. The converters are still original as are 2 of the O2 sensors. There is occasionally a puff of oil at start up, and I can smell a little oil in the exhaust if it idles more than 5-10 minutes. It still passes all emission testing and gets close to 20 mpg on the highway. It's just not worth putting money into a truck that is likely worth less than $5000 for something that really isn't an issue IMO and experiance.
Old 11-21-2006, 12:47 PM
keith97xlt's Avatar
wow! 305,000 ?? if that thing dies next week you got your moneys worth.those 4.6 are bulletproof
Quick Reply: oil consumption 4.6L
