F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > V8 Engines
Thread Tools Display Modes
Old 08-13-2006, 01:43 PM
1989 F150 300 6 Bucking and Jerking help!!!
I have an 89 F150 with a 300 6 cy with fuel injection. It has 200K miles on it. About 5K miles a go I had the injection system cleaned and fuel filter replaced and it fixed a bunch of problems but the computer showed that the O2 sensor was sluggish and the EGR valve was bad. It still ran good so I ignored those two issues. Now, 5000 miles or so later, it has started jerking and bucking at lower rpm's. I replaced the O2 sensor and EGR valve last night ($165 Ouch!!) and the problem is still there. There is no check engine light lit and I checked the plugs and they looked good. The plug wires, cap and rotor are newer and appear good. Also at an idle the rpm's fluctuate when cold and the engine seems to run rough when at a warm idle. Any ideas would be greatly appreciated. I had one person suggest that I plug off the vacuum hose to the EGR valve and see if it ran better and if it did then what ever is controlling the vacuum is causing the problem. I haven't done that yet.
Thanks guys!!!
Old 08-13-2006, 01:53 PM
Do a compression testand see what you got it shoukld be in the 150 range. This would rule out any bad stuff in side. Good luck.
94 4x4 5.8 newly rebuilt 155000 miles we call it the white trash and 04 4.whatever 2x4 my wife drives it.
See my rides.
http://www.f150online.com/galleries/....cfm?gnum=8089
Old 08-13-2006, 02:25 PM
Tested all cyclinders
I did a test of all cylinders and they were between 115-135 cfm or so. From what I understand that isn't bad as long as they are all close in the same range. I did this test before the fuel injections system was cleaned. Does not burn oil and oil appears clean and free from any water or anything.
Old 08-13-2006, 06:33 PM
How does the exhaust feel. Have some one rev it a little and put your hand over the pipe to see if it feels normal. Try to see if it is obstructed as the cats could be clogged. Check for a cracked dist cap or faulty wires. Check timing. Has the timing chain ever been replaced. Put on a timing light and look to see if the timing moves around it should not if it does the chain could be stretched.
Old 08-20-2006, 04:32 PM
Took the truck in to have it hooked up to the testing machine. All sensor look good. The mechanic again pointed to the injectors and said that since we cleaned them three months ago and now they are causing a problem again we should replace them. $400 I think I will try and do that myself. Napa has a shop that will remanufacter my old ones if I bring them in for $27 ea. Anyone know of the difficulty of removing the injectors out of a 300 6, any suggestions or hints would be greatly appreciated.
Old 08-20-2006, 07:34 PM
my old '91 did just what you describe. New IAT fixed it. The old one was caked with grime/oil/poo. I didn't get any codes, BTW.
Old 08-20-2006, 08:37 PM
What is a IAT and where can I find it? I guess I'm a bit green on it.
Old 08-22-2006, 07:27 AM
Vehicle: 1995 Ford F150
Intake Air Temp sensor. Look at the #1 cylinder intake manifold passage, close to the head.
Webmaster:
Rice Haters Club
My F-150 Gallery
'95 Eddie Bauer F-150 SC SB / 4.9L / 5spd / 3.55 LS / K&N FIPK w/ Ram Air / JET / Crane / Taylor / Comp Cams / Edelbrock RPM / Hurst / Add-A-Leaf / Bilstein / Bridgestone Dueler A/T Revo 31x10.5R15's / Auto Meter Sport Comp Vac, Volt, Water, Oil & Fuel PSI / K.C. / Optima Yellow / Alpine / Apple / Toshiba / Boston Acoustics / Polk / Bazooka / And more...
Old 04-02-2007, 04:01 AM
some what the same issue
I have a 89 F150 with a 4.9 manual trans and dual tanks. the issue is after the truck runs fore about 10 min I get a soft hum from iside the cab ( have not been able to determine the location). as the truck runs the hum will get louder until it cuts in and out. At that time the emgine will skip and stop. This happens both at idel or running down the road. I have changed the Fuel pres reg. the external fuel pump and the fuel filter. I have not had any engine lights indictors. any ideas are welcome.
Old 04-02-2007, 01:26 PM
Vehicle: 1983 Ford Bronco
Try to duplicate the hum with it idling in your driveway, then try to find it. Try disconnecting or pinching off various rubber vacuum lines to check the effect. DON'T pinch the hard plastic ones, but plug the suction side of anything you disconnect.
Old 04-02-2007, 03:19 PM
Vehicle: 1997 Ford F150 5.4L
This motor does not have a timing chain. The cam Gear and the crank gear mesh together, so no chain stretch possible. Could be slop in the gears, but not so much. I'd look at ignition. Mine was really bad for moisture in the cap. She'd buck like a Bronco, but I had an F150. hehehe
Old 10-12-2009, 05:24 PM
Vehicle: 1989 Ford F-150 4x4
Send a message via ICQ to perry211
Take the Vac line off of the EGR. If the engine runs good then the EGR is bad, Or the cheaper fix, The vacuum control valve. Located in the middle of the block at the rear. You can follow the vac line around the rear of the motor to the controller. To test the vac control take the elect plug off of it, Start it up, If you still have vacuum at the EGR line, The vacuum control is bad. It sells for around $40.00.
Old 10-12-2009, 06:21 PM
Vehicle: 1993 ford f150 xlt
Quote:
what the hell is giving you the idea that these are egr issues?
Old 10-12-2009, 07:03 PM
Vehicle: two 2003 F-150s
Send a message via AIM to Patman03SprCrw
If its an EGR issue, and still getting flow efficiency codes, I would also clean the passage through the intake between the air stream and the EGR valve
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
