How do you check and find a vacuum leak?
on
Using a can of engine starter fluid spray the suspected hoses and connections. If the engine speeds up while you are spraying the leak is in that area. When the fluid gets sucked into the engine via the leak it casues the engine to speed up because it mixes with the air that is also being sucked into the engine.
JMC
JMC
on
Well, there's two stories that stand out in my mind, one with me and one with a guy I worked with. First, me. Looking for a vacuum leak in a friend's '95 Mustang. Okay, no problem, start spraying around the intake manifold, got a little too close to the distributor and WHOOSH! Yes, eventually, my eyebrows did grow back.
A more recent one involved a guy I worked with. He was finishing up a 3.8L head job on a Taurus. Took it on a road test, came back and left the oil filler gap off, spraying oil all over the front of the motor. So, he leaves the engine running and takes off to spraying brake clean around the exhaust and spark plugs to clean the oil off. The whole building rocked with the concussion from the flame. He runs across the shop like a cartoon, smoke trailing from his head, blew his eyebrows off and singed all the hairs on his arms.
So do be careful when looking for vacuum leaks with flammable chemicals.
leaks
I really like the method of attaching a vacuum cleaner to the exhaust pipe. After you have a good strong connection, and no leaks around the pipe, you can use some type of smoke device around the engine compartment. Anywhere that you see smoke going into the engine is a possible vac leak. Just using smoke is much safer than flammable liquid. Or if your not to hip on using smoke you can spray some water around the engine. A little water in the combustion chamber should not be a big problem.
Or you can just look for the obvious hose off. Not to many on these new ones. Unless you have a leak around the intake gasket. I just had one on my old 72 at the power brake booster. Seems it was the booster that was leaking.
Did I miss it or did you say what the motor was doing or not doing?
