Location of the coolant drain plug on 5.4L
Old 05-31-2005, 05:01 AM
sormi's Avatar
Can anyone point me to the coolant drain plug location on the engine block for a 97 5.4L F-150. I've checked the post's and they only mention the 4.6L.
Thanks..
Old 05-31-2005, 12:47 PM
JMC's Avatar
JMC
JMC is offline
Here is a picture of the driver side on a 4.6. It will give you an idea of where it should be on the 5.4. The second picture is from the 5.4 in my truck. It has a hex bolt in it to plug the hole. The frost plug has a block heater in its place. The bracket to the left of the heater is part of the motor mount.
JMC
4.6 driver side
5.4 driver side as seen from under the truck
Quick Reply: Location of the coolant drain plug on 5.4L
