On your 1997 FORD TRUCK F150 1/2 TON P/U 4WD, the FUEL FILTER is:UNDER VEHICLE, DRIVER SIDE, BELOW SEATING AREA, NEAR FUEL TANK, MOUNTED ON FRAME RAIL IN FUEL LINE
Pcv valve can be straight of 90 degrees like the one in the photo.
I still have the original one in my 98 with 112,000 miles. Real easy to check, Just remove shake and if it rattles it's OK. Check the grommet it fits into and the hoses associatted with it.
I will run some carb/throttle body cleaner thru it from time to time.
Forgot all about the schraeder valve for the fuel rail. Had me puzzled.
