Milky Oil Cap
Milky Oil Cap
Recently I've noticed the underside of my oil fill cap is milky. Could this be the begining of a head gasket problem? The oil itself appears clean and clear after 2000 miles (Mobile 1).
It has been cold and rainy for days so I considered possible condensation or a leaky cap. I swapped out the cap with no change.
Engine at 157,000.
Any body else experience this milky cap or am I screwed?
All input is appreciated.
Engine at 157,000.
Glad to here it!
Thanks that puts my mind at ease.
As for the oil I check it constantly and keep it at the full mark and it does look good. Remarkably good for 157,000.
I considered loosening the drain first thing in the morning to see what was on the bottom but with your reply and the fact that the resovoir is still topped, I'll just keep an eye on it.
Bye the way I did notice the same film in the filler neck.
Thanks again.
Thanks again.
I had an F100 w/ a straight six that always did the same in cold weather. I did the same as T-bird and covered the upper half of the radiator hoping that it would divert most of the cold air from going around the valve cover and upper part of the engine. It did reduce the milky stuff some but a longer trip was still better. If your PCV vale is working I dont think that the milky residue will do any damage.
Good luck.
Good luck.
