2000 5.4 Triton Problems Help!!!! - F150online Forums
Old 07-03-2004, 01:00 PM
Hello Everyone. I am new here so any help would be greatly appreciated. I just bought a 2000 F-150 with the Triton 5.4. After a week of happy driving It started running real rough. I hooked it up to a computer and it gave me a cylinder 7 misfire code. I replaced the coilpack and a new plug. After that it started reading a cylinder 5 misfire. I replaced the Throttle pos. sensor because it was reading 19.2% at idle. None of this has helped. It has no power the check engine light is on all the time. HELP ME PLEASE!! Do I need to keep replacing coil packs until the problem goes away????
Old 07-03-2004, 01:38 PM
Did you wash the engine compartment bay?
If you did, you might have gotten some water in the spark plug holes...
Old 07-03-2004, 07:08 PM
Yes I did. What should I do??? Replace plugs???
Old 07-04-2004, 03:16 PM
you might as well replace the plugs cause you'll have to remove the cop's to fix it.what you need are just the rubber boots for the cop's not the whole thing.the boots wear out and let water down in the hole causing it to misfire.they're about 5 bucks a piece,alot better than buying the whole cop
Old 07-05-2004, 12:04 PM
Thanks for the help. I will replace those ASAP and see what happens.
Thanks Again
Old 07-05-2004, 12:59 PM
You need to get water out of the plug holes. You can remove the cop's and blow the water out with an air hose or if your engine runs let it idle for about 30 minutes.
The air hose method might prevent damage to the COP boots that could occur due to arc'ing.
I do not know beans about the length of time required for water in the spark plug hole to cause boot damage in a running engine.
See this thread...
Water in coil?
Related Topics
Thread
Forum
Replies
Last Post
MilltownMoose
08-13-2015 12:10 PM
silver fx4 5.4
08-05-2015 07:55 PM
karavansman
Wheels, Tires & Brakes
5
08-03-2015 06:19 PM
Ghemp
V8 Engines
5
07-17-2015 09:29 AM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
