What does a burnt valve sound like?
I have what sounds like a small exhaust leak coming from the passenger side. I have check for leaks on both sides of the mainfold. No leaks detected. The sound changes with rpm. If it is a bad/burnt vavle, how can you tell without pulling the head? I have not had any CEL's. Will a bad/bent valve cause any further damage?
Thanks guys. I have checked around the intake, plugs and exhaust by listening through a rubber hose. No luck. It is only noticable while driving when the motor is under load. It must be to faint to hear at idle. I have heard of the number 3 cylinder giving people trouble when running headers. I will recheck those plugs just to be safe.
