How do I set the ign timing on my '92 F150 5.0L?
I'm used to woking on Mustangs where you pull the "spout" when you set the base timing. Does the truck 5.0 have a spout? The distributor looks different than the car 5.0, where the module is mounted to it. The truck distributor has a spot where the module would go, but nothing is mounted there. (I'm sure you guys knew that, but, I just got this truck and it's new to me.) So, can someone breifly explain the procedure????
Thank you.
Thank you.
