Ignition Problems
Ignition Problems
My 5.4 suddenly started missing on 4 cylinders at once. Codes are P0351, P0352, P0353, & P0357
Coils were tested OK by dealer.
Crankshaft Position Sensor was replaced
PCM was reprogrammed by dealer
Nothing has fixed it yet.
These are the first 4 cylinders in the firing order
Anyone ever seen this or have any ideas for a fix
any help appreciated...
on
I replaced the Crankshaft position sensor before I took it to the dealer. It was an inexpensive part and guess work.
I think the dealer checked the injectors. Not sure. The OBD codes says mal****ioning primary or secondary coil. Dealer says the coils are not firing or getting trigger signal, they just do not know why. I'm trying to locate a Ford wiring diagram for it to see if the leads are close together where they go through the firewall to the PCM.
1997 Ford F250 XLT Supercab with 5.4
