Good Heavens....
...these engines operate well above 90F or any other ambient (air) temperature we see in the USA, so any time we start them here on Earth it is a cold start.
I would like to see the detailed mechanistic analysis fo why anyone would seriously recommend a 10w-xx oil when a 5w-xx oil is specified by the manufacturer. The film strength (protection) is a function of the viscosity, which is a function of temperature as mandated by the API/SAE spec. Doesn't matter how many times the oil has been cracked (whether type II, or VI or whatever); the viscosity specs are clear, and fluids meeting those specs will provide the tensile film required to protect against breakdown in the cylinder, whil eflowing through all the aperatures at the pressures submitted by the pumping system throughout the temperature curve.
Ford indicates (and has never wavered from) the 5w-xx oils. Works great.
