F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > V6 Engines
Thread Tools Display Modes
Old 10-11-2009, 06:10 PM
Vehicle: 1996 Ford F150
Unhappy Rough Start
I have a Ford F150 6 cyl. Sometimes when I start it, runs rough and even kills the engine like it out of gas. All I do is swap tanks (to the back tank) it starts/runs just fine. If I try it on the front tank again and swap to the back before the engines kills it runs fine and after I get going I can swap back to the front tank like nothing happened. Any suggestions.
I hate to bring it in without a shot at it myself, the check engine light is on too. Thanks.
Old 10-12-2009, 02:10 AM
glc glc is offline
Vehicle: 2003 Ford F150
You need to read the DTC codes. A 1996 is OBD2, and Autozone will read them free. Go get them read, and then post the exact codes - they are 4 numbers preceded by a "P".
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 10-17-2009, 07:36 PM
The error was P0171, engine running lean, the guy at the store said i should replace the air filter. I removed the cover it was clean, disconnected the battery to clear the error and that seam to work. Did that sound right. Oh and thanks for the autozone tip.
Old 10-18-2009, 12:42 AM
glc glc is offline
Replace air filter for running lean? He does not know what he's talking about - you replace the FUEL filter if anything. You also check for vacuum leaks.
Then again, if you are having tank switching and fuel pump issues, that could trip a lean code, it makes sense.
Old 10-25-2009, 03:35 PM
Rought Start
Thanks, I did have a vacuum line that was cracked / broken. I started to change it and it fell a part. I replace 4 line total some with surface cracks. The line that fell a part was on the inside side of the that ever it’s connected to (sorry I have not idea what this is, it's connected between the air filter hose at the manifold). I cleared the code and will do a test run today. Thanks again.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
