F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > V6 Engines
Thread Tools Display Modes
Old 10-05-2009, 10:22 PM
4.2L codes P0171 and P0175
I have a 2004 f-150 heritage 4.2L v6. The service engine soon light came on and it started running bad. It hesitates and skips when accelerating and has rough idle. I had it scanned and it showed codes P0171 (too lean bank 1) and P0175 (too rich bank 2). I cleaned the MAF sensor, changed the fuel filter, and changed the O2 sensor on the driver's side. Still showing the same codes and still running rough. Help please, I am in the military and don't have alot of free time to take it to a shop.
Old 10-05-2009, 10:41 PM
Vehicle: 2003 Ford F-150 2wd
Vacume
Check for vacume leaks. All hoses and even the ones that are near the rear of the engine.
Old 10-05-2009, 11:28 PM
how can i check for vacuum leaks. what equipment do i need?
Old 10-06-2009, 05:23 AM
Vehicle: 2007 Ford F-150
Vacuum Leak Check
Get a can of WD-40 and spray where you may have a possible leak. If the motor revs you've found the area of the leak. Then isolate the exact location.
2007 STX Reg Cab 5Spd V6
Old 10-06-2009, 10:20 AM
Vehicle: 2002 Ford F-150
Specifically, I'd check\replace your PCV elbow. It's a common issue with our engine and it's only about a $15 part I believe. I had the same issue on my truck around 90K miles. I replaced the PCV elbow, upper and lower intake gaskets and the isolator bolts for the plenum, which I believe there was a TSB for. Good luck.
02' F-150 XLT Sport | 4.2L | 4x2
6" RCD lift | 4.56LS | RCD rear traction bars
Troyer Tuned XCAL2 | AF1 intake
285/70/17 BFG AT KO's
Old 10-07-2009, 03:49 PM
Quote:
Chris, would i be in the clear for the intake gaskits? Mine is an 03 and uses no coolent.
Old 10-07-2009, 04:01 PM
Quote:
Not necessarily. I think you are referring to the lower intake gasket issue that caused the hydro-lock on the 97-98's due to coolant leaking. My issue was my upper intake manifold or intake plenum. What happens is, the rubber gaskets get worn out causing a vacuum leak, a very common issue on our engines. I also got a new set of isolator bolts (from Ford parts desk) to fasten the intake plenum. Since we were taking it all apart, I went ahead and did the lowers as well.
Old 10-12-2009, 01:54 PM
Well, I ended up taking it to a shop.....It turns out that the catalytic converters were bad and were triggering the codes. I had them replaced and no more problems. Thanks for all the suggestions.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
