F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > V6 Engines
Thread Tools Display Modes
Old 06-25-2009, 06:08 AM
glc glc is offline
Vehicle: 2003 Ford F150
Quote:
doing this to a stock engine probably wont be worth it.
I coulda told you that before you started.
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 06-25-2009, 03:03 PM
Vehicle: 2001 Ford F-150
Send a message via AIM to dirtyd88 Send a message via MSN to dirtyd88
Quote:
Originally Posted by Raptor05121 View Post
well.....im done. i even put some buffing compound and polishing compound when i finished and on my CAI tube.
Pros and Cons.....
Pros: On the initial test drive my "seat of the pants" dyno yielded considerable gains. 1st gear gets more low-end power, 2nd and 3rd's top-end are in love with me now.
Cons: Idle dropped from 850 to 750....ehhhh.....and my SG2 shows a TPS reading of 22 (should be 20). I took the buffer over the butterfly, so i may have knocked something out of alignment. Its not DIRE but not something I want permanent either. but the gains are noticeable. I'm no HP expert (as many of you know) but I'd have to say AT THE MOST is maybe 5 hp.
For the reasons associated with the risk in maybe screwing something up, I opted out of doing a write-up. I'm sure if anyone wants to do this later on, its pretty simple, but its just "iffy" right now until I can bump up my idle...
Note: the risk in doing this IMO is not great enough unless you are going "all out" I should say such as CAI, efans, UDP, exhaust and maybe turbo. doing this to a stock engine probably wont be worth it.
Get a programmer and and you can fix your idle issue!
You want to do me one in trade for some shackles maybe??
Gallery of my 2001 F-150____________________Exhaust & System Videos
<--Click Me, Please!
│Depo Black L heads w/ 5K HID│Depo Diamond fogs w/ 5K HID│Belltech 2" shackles│
│Lightning Bilsteins│VMP Tuned│K&N '77 Series CAI│18" Magnaflow SI/DO│
In the works: PTM tailgate handle, removed side molding, cut L coils, 2" drop hangers, and a Horn Blaster's Bandit 300 setup
Old 06-25-2009, 05:58 PM
Vehicle: 1998 Ford F-150
Send a message via AIM to Raptor05121 Send a message via MSN to Raptor05121 Send a message via Yahoo to Raptor05121
Quote:
dosent matter, mines not stock, i still would have done it. i was referring to people who dont have a darn thing on their engine. i have a CAI, efans, and soon to have UDP and a tuner, so it does its part to help
Derek, if I can find one, i'll do it for ya in swap for some shackles! i was just thinking how I spent $20 on sanding wheels only to use them once. maybe it looks like i'll be able to use them again! do you have a spare or access to a spare? at the moment my local JY has nothing but tritons. and you say a tuner will fix the idle issue? cause if i did it exactly like i did mine i think you might have an idle issue. but i think i know what is wrong with mine, so im going to go outside and see if i cant fix it. but if you come across a 4.2L TB let me know and i can do it.
Old 06-25-2009, 07:14 PM
Vehicle: 2006 Ford F150
Send a message via AIM to ScottFF00
You have to be kidding us. You seriously think you used a dremel and did alittle work to your throttlebody and now you feel the difference. Anyone that belives this must be smoking the same thing as you. Stop spread all this misformation here.
The truth about all your mods work is....you put EFans on and your truck overheats. Now you P&P your throttlebody and you have an idle issue.....
Technical Article 101:
-How to overheat your truck for 100 bucks.
-How to screw your idle up for free.
Old 06-25-2009, 07:21 PM
Vehicle: 2004 Ford F150
Send a message via AIM to TruckGuy24
Don't beat him up man...play nice
John
Thanks Watson91 at S-FX
PTM Century Tonneau
Remote Start
14" si/do Magnaflow 45'd behind rear tires
4" x 18" SS Tips
Roush Grille
Billet Bumper Grille
PTM Mirror caps
DVW Intake w/ K&N drop in
Quote:
Originally Posted by 05RedFX4 View Post
Best of luck to you, and hopefully you don't have the same attitude when you go into the dealer to get your trans fixed, because if you do your gonna need a big jar of vaseline cause they are gonna stick it to you, HARD
Old 06-25-2009, 07:28 PM
Alright. Sorry
Old 06-25-2009, 07:32 PM
Vehicle: 2007 Ford F150
No pictures at all? You could have at least taken before and after pictures.
Old 06-25-2009, 08:05 PM
woot! my hunch payed off. i was sitting on the john thinking about my idle problem and immediately ran outside (after wiping and flushing of course) and i realized....my butterfly was backwards.
in the idle position, the butterfly sits at what looks like not a perfect vertical angle, but like a 91 or 92* degree incline, which diminishes to 0* as you open the throttle. well, since its sits at this angle, the rim of the butterfly was cut at an angle to sit flush with the face of the wall of the TB. Well while i was porting it, i took out the butterfly and ran my 180-grit over it very lightly (took that dull brown color and now looks like polished gold) and when i reinstalled it, i had it bass ackwards so it was completely wrong...thereby allowing more air in, throwing off the IAC. so i flipped it around, reset the computer and upon crankup...sure thing. she climbs to 650...700....750...790.... then i take it down the driveway and back and in neutral she sits at a modest 850 RPM. yay!
Scott, its okay if you don't believe me. i didnt do this to impress you. fact of the matter is i felt a difference and my other F-150 buddy drove my truck around and immediately wants me to do his now. I'm not saying im going to go out racing lightnings now. but if you want to chip some money my way, i'll gladly find another stock TB and drive to jacksonville and do a dyno for ya
and i dont have an "overheating" problem. with the 102* weather we've been having my truck is sitting at 205 degrees, but that is not a problem.
4.2L V6 - M5OD | 16" Dual Efans | 2" Drop Shackles | K&N Series-77 | Port & Polish TB
Bent Frame Mod | Custom Down-Turned Bumper | Accordian-style bed flooring
Old 06-25-2009, 08:07 PM
'Seat of the pants' aka 'butt dyno' readings are notoriously inaccurate.
Any change in power delivery or sound is perceived as 'more power' by the guy who spent the money and/or did the labor. Real changes should be verified using controlled experiments. Corrected dyno, 0-60 times, unbiased tester, etc...
As for a minor (5 hp?) gain, your actual peak power can vary that much or more with the change in the weather between breakfast and lunch. It is very difficult to measure changes that small with an instrument as unreliable as the butt dyno.
IMO, reducing air velocity through the intake by hogging it out is rarely a good idea, unless you are correcting a known deficiency.
Polishing a surface to increase airflow has been pretty thoroughly debunked over the years, specifically for intake ports. Pretty sure the same physics apply in the intake tract.
But hey, it's fun to work on your truck and learn on your own, so props for that!
Old 06-25-2009, 08:16 PM
Quote:
well, i intended to do a full-scale write-up but my parents borrowed my camera for the week (went on a vacation on the Harley) so all i had was my camera phone. i didnt get any before shots, but i did get a few durings and after. i cannot seem to setup my alltel upload album so unfortunately, no pics for now
i wouldnt say reducing the air velocity. if you could see the difference in diameter of my CAI tube to the rubber o-ring to the TB, this helped reduce some of the turbulence that the various-sized openings caused. and while i agree with that and would love to dyno it, all i can say is that it didnt hurt the performance either, so either way, im proud of it. plus im moving to tally soon, so i might find a shop and do a few pulls and let you guys know
Old 06-26-2009, 12:58 PM
Quote:
I concur. If you search the old threads, you'll see that Alex has taken all sorts of abuse from everyone here; for just about anything you can imagine, and some things you can't imagine. It's time we leave the kid alone. We've already had enough laughs at his expense. Just search the old threads.
Old 06-26-2009, 02:54 PM
I will be in touch!
Old 06-26-2009, 03:07 PM
Quote:
So you want us to not laugh at his expense, but we should search the old threads where we will laugh at his expense?
This is the internet. It's better when it's entertaining.
And if someone posts inacurrate information or uninformed opinions in an open forum, they should be called out on it, IMO. That's how people learn.
BTW, if a post is truly abusive, report it to a moderator.
Old 06-26-2009, 03:15 PM
It's not meant to be a tattle type thing, but honestly, it really isn't just the internet. Respect others just like the way you would in person. I see this too much and it kind of bothers me. I got the same thing when I messed up painting my chassis a week or two ago. It's needless gripes that are intended to provoke a response. I understand that there is usually no harm, but there are jokes and then there are comments that are used to create a sense of shame or such on the OP or the directed of the comment. Sometimes I see these comments and it reminds me of the playground in elementary school. I know where you are coming from DDD, but it still doesn't make rude comments right.
John
John
PTM Century Tonneau
Remote Start
4" x 18" SS Tips
Roush Grille
PTM Mirror caps
Old 06-26-2009, 06:17 PM
That is the theory, but I've seen parties with advanced knowledge report that a shiny surface does little if anything to promote air flow.
Basically, there is a 'boundry layer' - a thin area of turbulent air near the surface, and it matters not whether the surface is polished smooth or not.
Bottom line is it may not be worth the trouble to polish.
That's why golf balls have dimples! Now that would be interesting to see, a TB with dimples like a golf ball on the inside.
--Dave--
2001 Wedgewood Blue Metallic Supercrew XLT 5.4L 4x2
Mods: Fabtech 7.5" Performance Lift, 5% tint, ARE cap, driving lights behind grille, black painted grille and front valance, 315/75/r16 Nitto Terra Grapplers, 16" Ion Alloy 174, and a Magnaflow 18" sido.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
