F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > V6 Engines
Thread Tools Display Modes
Old 06-10-2009, 11:55 AM
1997 f-150 v6 rear end vibration
My girlfriend's brothernlaw has a 97 f150 with a 4.2 v6, auto. the problem is with the rearend. I beleive that the pinion bearing has gone. the seal leaks slightly but when you physicaly move the shaft, you get lateral movement. Iwould like to know the instructions for rebuilding the rearend. I beleive it's an 8.8. I've doen a 7.5 in a ford bronco II. Is it the same style and I need the parts required. I hope the ring and pinion are not damaged. I just beleive the pinion bearing is worn.
Old 06-10-2009, 07:41 PM
Vehicle: 2000 ford f150
pic up a rebuild kit from richmond on even the dealer and its the same process pull the cover pull the set pin the pull the spiders retainer pin slide each axel in pull the c clips slide the axels out pull the carrier main bolts pull out the diff then loosen up the pinion nut hit the pinion with a brass punch to freeit up pull off the nut slide out the pinion replace the bearings and the crush sleeve the reverse it should only take you 3.5-4hrs (note make sure you change the crush collar and also make sure you put the correct gear oil because thats how mine was blown up no 80-90w at least mine takes 75 140w synthetic )
Old 06-10-2009, 11:16 PM
FWIW, a common cause of rear end vibration on older vehicles is a right side axle bearing. I would look into that before rebuilding the rear end.
When do you get the vibration?
Old 06-10-2009, 11:30 PM
Vehicle: 2001 Ford F150
I'm going on 220,000 miles and the rearend has never been touched, including fluid changes. My dad bought the truck brand new and I know he never touched it before I bought it off him. I guess I'm just lucky?
Knock on wood by the way. I should get those new gears put in and change the fluid now.. shouldn't have said anything.
Old 07-17-2009, 07:23 PM
Hmmmmmm.......I've got a '97 V8 (not that it matters in this case), but I get a vibration when starting forward (traffic light, stop sign, etc.). I seem to notice it when I'm making left hand turns. Wonder if that has anything to do with it. Hadn't thought of the axle bearing.
AF
Old 07-18-2009, 04:16 AM
glc glc is offline
Vehicle: 2003 Ford F150
If you have limited slip, change the fluid and make sure you use the recommended fluid and modifier.
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 07-22-2009, 01:43 PM
I'll check that out as soon as I can.
thanks,
AF
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
