If your original owner's manual is missing, download a soft copy from www.fleet.ford.com under the MAINTENANCE tab.
1994 Taurus SHO 3.2/ATX
1989 Taurus SHO What a project! Retired at 249K.
1997 Ford F150 SC 5.4L New Work Truck
1998 Ford Contour Wifey's old daily driver
2007 Mercury Mariner AWD
You can go to any parts store and look in the "HELP" section for a rubber 90* elbow close to what you need until you can get it from Ford.OR.......use an old spark plug boot.
__________________ 2007 F150XL,4.2V6,3:55 non L/S,auto
Dark Blue Pearl Metallic
Injection is nice but ide rather be Blown!!!
I've got lean codes and stuck intake runner codes. Would a vacuum leak at the PCV produce the runner codes? Or am I stuck trying to figure out what to do with the runners?
From what I can tell on the forum, this is a predictable problem at about 120K. But unless it is the PCV thing, it's a higher-skill problem to fix.
Thanks, Blue Oval, for the lead. I'll save the link to your IMRC post, since it seems like there are inevitable problems with them.
I ended up taking my truck in and I feel stupid - it was just battery-acid corroded vacuum lines behind the batter (this, too, seems pretty common for guys like me who don't keep that area as clean as they should). $175. Oh well, I'll write up a problem-specific post for guys who run into the p1537 and p1538 fault codes. I'm notorious for thinking it's the worst problem when it's really the simplest, so maybe I can save some other guy a lot of money and poking around.
Question: you guys are talking about running Seafoam through the system on the link your had - how do you do that with fuel injection? I've used it a lot on motorcycles by just running it into the carbs.
You run seafoam in by the brake booster vac line . Take the line off the booster and place it in the can , let it suck about half the can and turn the motor off , let it sit atleast 30 minutes , I do it overnight . Then start it up and drive , will smoke like crazy for a few miles .
Don't use Seafoam that way, unless you could care less about your engine and other components , -long or even short term. If you don't eventually Hydroloc, you'll fire up the converters one to many times and melt the cones together.
Black smoke = Converter's on fire from carbon soak.
White smoke = Product cooking.
You get a BG service or Motor-vac Service to clean internals properly.
I have been doing the Seafoam for years , never once a problem on any of my Trucks or cars from it ... I guess is some idiot done it wrong you could screw it up , but I have never had a problem from it ........
Well for years you have been fooled. I'll tell you that right now lol.
The manufacturers of your Ford product have engineered service and chemical that has proven to be the best for these set ups. There isn't a miracle in a can such as Seafoam that can match this service or even come close. In-fact it can have adverse effects and has. Just because a handful of users have gotten away without these effects doesn't mean the product has done them any good. There's been problems posted in the past with a direct relation to using Snake-oil.
The BG and Motorvac are safe and do what there meant to do without question. The choice is yours.
