3.5L Ecoboost Rev Clunk
3.5L Ecoboost Rev Clunk. Help!!!
When ecoboost engine is first started it makes a clunk noise when rpms come to idle. Once truck is revved to 2000+ rpm and returns to ~1500 rpm and more pedal is then applied to bring it back to 2000+ the noise happens. As you can see in the video the truck is kept in this range with multiple clunks to exhibit the clunk. Once the truck returns to idle (~500+) at the end does it as well. This happens constantly while driving and slowing to a stop or when coasting and pressure is applied. The dealer supposedly fixed issue by changing the bov but problem persists. Any help would be appreciated.
I don't think that's a timing chain sound, especially with only 17k on the clock. Look up TSB 14-0194 to see the test procedure for the timing chain stretch. Typically there's a code or two thrown. If you have an OBD Bluetooth adapter download the app FORScan. The free version will only show one item at a time but it does allow you to check the parameter listed in the TSB.
