Bad cold/first start 2007 4.6V
Old 04-29-2016, 04:47 PM
Jasper220's Avatar
Bad cold start 2007 4.2 v6
Hi guys,
Im owned a Ford F150 XL reg.cab 4.2 V6.
I bought it 2months ago. No idea off any history, so i changed the oil, filters, air filter, plugs wires and coilpack.
But i've got a problem. When the truck stays a while, it has a bad start. It takes 10sec till it will run and runs not very nice, a bit rough. When i drive a few km. Its better and runs and drive OK.
When i drive a longer distance it will starts directly when it stays about 6/7 houres.
Sometimes it looks like it will starts at once but then u can hear it wil not run in 10sec.
Anyone any ideas?
Thanks!
Old 04-29-2016, 04:52 PM
Jasper220's Avatar
Originally Posted by Jasper220
Hi guys,
Anyone any ideas?
Thanks!
Oh. An no codes and no light
Old 04-29-2016, 06:43 PM
glc is offline
Check the backside of the FPDM for corrosion. It's on the frame rail above the spare tire.
Also, you may have leaky fuel injectors.
Old 04-30-2016, 03:56 AM
Jasper220's Avatar
But i hear, the FPDM will be Ok or defect. Or is there a way between it? Car drives ok on gasoline.
Old 04-30-2016, 11:01 AM
2008_XL's Avatar
Yes it can be I between. Sometimes working, sometimes not. Check it to be safe.
What brand plugs, wires and coil pack did you use?
Old 04-30-2016, 11:03 AM
Jasper220's Avatar
Ive used all motocraft.
Old 05-01-2016, 06:38 AM
Jasper220's Avatar
You mean this FPDM?
Old 05-01-2016, 10:16 AM
glc is offline
Yes! That's shot.
Old 05-01-2016, 10:44 AM
2008_XL's Avatar
You mean this FPDM?
That's definitely the issue. It's cracked in half.
Quick Reply: Bad cold/first start 2007 4.6V
