'97 Ford F150 4.2L V6 crank but no start
I have been at this issue for a couple of months now. Up until this point, I have seemingly solved the problem many times. Now I cant get it too start at all. The truck will turn over, but will not start/catch. Battery is good, all lights inside come on fine, they do not get dim or anything when you crank the vehicle. Starter has too be good because the engine does turn over. Repair history for this issue includes, new Crankshaft Position Sensor, new Camshaft Position Sensor, new Ignition Coil, new Spark Plugs, new Wires, new DPFE Sensor, new EGR Valve Vacuum Control(?) (I think that is what its called), new Throttle Position Sensor, removed the Throttle Body off the Upper Intake Manifold and cleaned it, cleaned the Idle Air Control Valve, new Thermostat (all I can think of right now). Thermostat was replaced due too a seperate issue. There are other repairs I have made too the vehicle as well, but they are not relevant too the problem I have now. My next course of action right now according to the reading and research I have done on the issue, is too replace the EGR Valve itself, also the ECT (Engine Coolant Temperture) Sensor. I know the coolant in the engine is good. Right before I had this issue, I flushed out the entire coolant system and poured in brand new coolant. As for the obvious, the vehicle has 3/4 tank of gas in it. I hear the fuel pump running when I turn the key too the On position. There is Oil. Right before this issue started, I also performed a oil change. Mobil 1 Full Synthetic. Any other suggestions would be greatly appreciated!
One thing I should mention. In the past, while having this issue, and replacing certain parts here an there, seemingly solving the issue. I would be able to get it started with a lot of priming the key, letting the fuel pump run a few times, pumping the accelerator, etc. I could for example get it started in the morning, drive it, park it, let it sit all day, an that evening, start it right back up! But after it sits all night, is when I am back with the same issue all over again. I just dont understand that?? I live in North Carolina. 20s, 30s at night right now. 40s, 50s during the day. The problem does seem too have gotten worse with the colder weather. During the warmer weather, the truck would act a little "cold blooded" in the morning, have to give it some gas while starting it, but it was never REAL hesitant.
Have you tried holding the pedal down slightly? What about holding it to the floor?
If the IAC is bad, holding it down slightly it should start. If the fuel injectors are leaky, holding to the floor will shut them off and let it start, clearing the flooded engine.
Nowhere do I see that you have changed the fuel filter or done a fuel pressure test with a gauge?
I did change the Fuel Filter as well. Forgot too mention that. I have held the pedal down too the floor while cranking it, and let it up slowly . That is how I got it started a few times before. I also performed this step the last time I attempted too get it started. Tried holding it down halfway as well.
Thank you. I am going too try that next. Do you know what would cause the fuel pressure too be low (if it is)?
The Fuel Filter was the very first thing that I changed when I started having issues. It didnt make it any better nor any noticeable difference. The pedal method worked for a short time. But its not working anymore. I tried just pumping it. I tried holding it halfway. Tried holding it too the floor. Tried holding it too the floor and letting it up slowly, all while cranking. Cant get anything out of it. It just turns over and over and over. It acts like it wants too start, but something is just not letting it. I can hear the fuel pump running. Ive cycled the key a few times before cranking. I will just have too see what the fuel pressure test shows up.
I am going too get too it this weekend. Thats my plan. Lately, I have either been busy or the weather doesnt cooperate. Honestly I really hope that test gives me something too go on. I know I've covered everything too do with ignition & spark. I have tested too make sure there is spark. Both from every location on the coil and all the plugs, in both directions. Everything is firing. Not too mention, all of it has been replaced with new parts. I will post the results on the fuel pressure test after I do it. I believe somebody replied on here and said, if it is less than 28 psi, it probably isnt going too start (?)
