2011 EB coil connector broken
Old 12-26-2015, 06:44 PM
Golfmanaz1's Avatar
I was doing my plugs today for the third time and after 150k miles some of the coil connectors broke. See attached pic. I have zip tied the connector on to the coil for now. Can the connectors be replaced with out replacing the whole wiring harness? Thanks in advance for any info.
2011 EB V6 Coil Connector
Old 12-26-2015, 07:46 PM
They get brittle with the engine heat.
Here is the replacement part information:
WPT# WPT-1284 (Silver)
FPN# CU2Z-14S411-AFA
You can either chop the old one off and solder in new connections, or by using a small pick, you can remove the pins out of the broken connector and put them in the new connector.
Old 03-01-2016, 07:18 PM
deadpool442's Avatar
There is some sticky black tar like stuff....you could put it between the connector and the coil pack. Seems to hold for me. Just a sticky mess when u need to change a plug
Quick Reply: 2011 EB coil connector broken
