can a 2002 4.2l ford be swap to a 5.0l
Old 11-03-2015, 10:42 PM
fer42's Avatar
Lightbulb can a 2002 4.2l ford be swap to a 5.0l
Can a 2002 4.2l ford f150 be swap to a 5.0l? My truck is a 5 speed manual with 103000 miles
Old 11-03-2015, 10:52 PM
Roadie's Avatar
Your transmission couldn't handle the power if you are talking about a coyote. the rear is too small too, an 8.8 when you need a 9.75. Trade trucks.
Old 11-03-2015, 10:58 PM
fer42's Avatar
So there's no way that it could be done
Old 11-04-2015, 09:41 AM
glc is offline
Are you talking about an old 302 or the new Coyote 5.0?
Old 11-04-2015, 09:58 AM
Anything is possible. It won't be easy, or cheap
Old 11-05-2015, 05:58 PM
fer42's Avatar
I'm taking about a new 5.0
Old 11-05-2015, 05:59 PM
fer42's Avatar
Yea your right anything is possible .
Old 11-05-2015, 08:53 PM
Roadie's Avatar
Engine, transmission, complete rear assembly, and computer controls and someone smart enough to make it all work would make it too expensive to even think about unless you have money to burn.
Old 11-05-2015, 10:47 PM
fer42's Avatar
Old 11-06-2015, 05:42 PM
fer42's Avatar
How about a 302 engine
Old 11-06-2015, 06:07 PM
glc is offline
A 302 is a much easier swap, it will bolt to your transmission and your rear and trans can handle it unless you modify the engine substantially. There will be electronic issues though.
My question is why? A 4.2 is just as powerful as a stock 302.
Old 11-06-2015, 08:10 PM
fer42's Avatar
well the reason why is because I would like to modify my truck
Old 11-06-2015, 08:43 PM
Roadie's Avatar
Just buy ishootstuff's V10 F150. He was trying to sell it a while back.
Old 11-07-2015, 12:25 AM
glc is offline
Modifying it with a stock 302 isn't going to do much of anything for you. Modifying it with a built 302 is going to be rough on the tranny and the rear.
Old 12-20-2015, 03:40 PM
SloMo's Avatar
New to the Swap and Forum Hello from the Boarderland
Hi. I'm doing the 302 swap from a 99 2wd 4.2 because the 4.2 blew gaskets and I don't want to drop the same problem back into it. The swap will be a great father and son project and coming up soon.
Question from you knowlegable folks: I got a line on a complete E150 Van 302 5.0 with all the electronics and just wanted to know if there is anything particular to the Van layout that I should be aware/concerned about.
Thanks for all your posts, been a great help!
Quick Reply: can a 2002 4.2l ford be swap to a 5.0l
