temp gauge never goes up..
1998 4.2 liter
i can drive the truck forever but it only moves a tiny bit, the needle never even reaches the middle of the gauge..farthest it ever reaches is where the little white line begins.
do i need a new thermostat?
i heard if i needed a new one my heater wouldnt work properly but my heat works nice and warm..
The gauges in these trucks are not meant to move with changes in conditions... Meaning, they are "idiot gauges".. You'd have to basically reach an overheating condition before the gauge will move to the 'hot' end.. Same with the oil pressure and volts.. They all have "idiot lights" with them too, so you'll see it come on too when the condition warrants.
I had a real water temp gauge in my 97 F150 and the stock gauge read the same from anywhere between 150* to over 210* on the real temp gauge. Never did see the stock gauge move even at 210*.
Change the T-Stat if you've never changed it, but your gauge will still read the same..
Mitch
Mitch
