'99 w/ 4.2 - Codes P0171 & P0174.
Hello!
First off, I'd like to thank all of the guys here for the amazing wealth of knowledge on this board, I've learned TONS of information in the last 2 days and it wouldn't have been possible without them.
I just purchased my first F150, it's a '99 STD w/ the 4.2L. It's got 73K miles on the clock and I just picked her up yesterday.
My question is this, I'm getting 2 codes: P0171 and P0174. Lean on Bank 1 and Bank 2. Doing some research here on the forums led me down the path of possibly a leak at the Intake.
I checked the PVC tube as I noticed some oil buildup around the top of the valve cover, but the tube checked ok and holds air.
What should I be checking for?
Thanks!
-Brian
Codes:
-P0171: System Too Lean (Bank 1) (Powertrain, Generic)
-P0174: System Too Lean (Bank 2) (Powertrain, Generic)
Thanks!
-Brian
Codes:
Just wanted to update this thread, I poked around the intake plenum with some carb cleaner and found a leak. During the gasket replacement I discovered 2 extremely worn vacuum hoses. I replaced them as well as the DPFE Sensor (the hose barbs were pretty much gone on it).
Now she runs great, lots of power and no more idle/stumble issues. The CEL has stayed off since the codes were cleared.
Thanks again for the help, I really appreciate it.
Just have to adjust the rear brakes and go over the front end and we are back on the road.
