97 f150 4.2l rough idle and acceleration
Hello e everyone any help would be great I have had this truck for about a week! When I got this truck the passenger side exhaust manifold was broke in to. So I replaced it but the truck is backfiring a lot and is missing . this motor sounds like it has a great motor until acceleration then it starts the mix. I have changed the plug and wires and no change. When I changed the plugs the ones on the passenger side were covered with sutty carbon and the drivers side was clean and look great. I don't know how much the truck was drove with the manifold in to. It Strick's me odd for this to be on the passenger side only . I tried to find a intake manifold leak and no luck!! PLEASE HELP!!!!!
wires
I have check and rechecked wires look good and how can I test the coil ? I have check to see if it is firing it appears to be good! (Not) that I know anything but in the past I have never had a coil to have 3 outputs go down. Could you give me some info on how to see if it is firing correctly? It seams to smooth out a little after the trucks worms up. I don't have a compression tester. Is it possible for all 3 cylinders to have burnt valves. Thanks fellas for the help! ! ! ! !
Here is a Picture of the proper firing order for the 4.2L V-6
https://www.f150online.com/forums/me...42-157048.html
I had the same problem you are discribing (SP?) & I ended up having 2 wires crossed on the drivers side.
All it takes is One Burnt Valve.
Good Luck!
