1998 v6 oil pressure gauge 0 wount start
i have 1998 f150 v-6.my oil pressure gauge is on 0 and truck turns over but will not start.please help.it had been running great and the oil gauge was working great and i parked it and came back and tried to start and noticed oil gauge was not moving and engine would not start.is there anything like oil sensor that would keep from starting
The oil pressure gage and starting are probably not related.
Either you are not getting fuel or have no spark.
Can you hear the fuel pump run for a few seconds with key turned to the on position?
When was the last time the fuel filter was changed?
Do not floor the gas pedal when trying to start, that caused the fuel injectors to shut off.
On the passenger side kick panel there is an inertia switch that shuts the fuel pump off in a crash, check to see that the red button is pushed down.
A fuel pressure test will help tell you which way to go, and you can rent/borrow a test gage at the big box auto parts stores for free.
Good luck
Good luck
