Atp at-205 re-seal
Atp at-205 re-seal
I have always been a firm believer in not using "SNAKE OIL" additives. Well, Techron and BG44K are the only exceptions.
I was in my local NAPA just recently (which caters mostly to farmers) and a farmer was picking up a case of this RE-SEAL. I started talking to him about it and he claims it actually works. He owns a fleet of machines for harvesting crops and uses it in all of them.
Has anyone else ever heard about this product or have used it?
Link does not work.
Regardless - sounds like more SNAKE OIL.
From a quick search ( you should try it sometime): http://www.bobistheoilguy.com/forums...al#Post3110618
So - it EATS certain types of seals. Wow. Sounds like a great product, eh? So ask yerself - do you feel lucky?
BTW - this has jack-chit to do with V6's. Try Other Aftermarket / Powertrain ...or GD....
Good grief ....
MGD
Good grief ....
MGD
I put a few ounces of TransX seal softener in the power steering system on a 1982 Firebird to stop the seal leak at the pump because I had pried on the pulley before finding the fourth bolt to loosen it. It stopped the leak almost instantly. One year later, both hoses were eaten up and leaking. The pump seal was leaking and the steering box was leaking. I had to replace the entire steering system that had been touched by that TransX. So, I would suggest that you not use it unless you have a leak and then flush it out once the leak is stopped.
Link does not work.
From a quick search ( you should try it sometime):http://www.bobistheoilguy.com/forums...al#Post3110618
Good grief ....
MGD
Good grief ....
MGD
But - yer special. The last few times I've attempted to reply and try to hep yall, ye never even bothered to to respond. Nada. Bupkis. You just disappear.
Yer manners leave a LOT to be desired - especially since we have BOTH been here for some time, and should be part of the Brotherhood by now. Hell - I even sorta git along with ol' Raptor - bless 'im and his relentless pursuit of knowledge. I Do respect that - very much.
Perhaps I expect too much - which is why I continue to respond to yer posts. In my own imitable way, of course.
GLC - you , if anyone, should know I am NOT 'always like that'. There is ALWAYS a reason. WTFF - Shame on y'all
Uh, in a word, no. This stuff is 100% by msds to be nothing more than a bottle of 100% Dow Carbitol. As such, it's an organic solvent. It's used in medicines, cosmetics, any place a mild solvent is needed. It's far from dangerous to any seals. Maybe the guy that claimed it damaged his seals already had damaged seals and the crud was all that was keeping his poorly maintained unit together. It's good solvent/cleaner but it's certainly not going to do anything but clean. It is not going to provide any seal swell agent to the seals so if you're using to condition seals, you bought the wrong product. A cleaner-yes, anything else is advertising hype.
Here's a vid of an intellectual in Canada that wants to teach you how to speak Canadian.
Speak like a Canadian - YouTube
First - thanks once again fer yer decipherin' of the MSDS. Perhaps someone should be so kind as to inform the Manufacturer of what's in their product - as they seem a tad clueless.
Second - it should not surprise anyone that you folks are somewhat bewildered by those who actually speak some form of the Queen's English, as opposed to the barely recognizable gibberish that passes as 'language' from down yonder.
I refer you to Exhibit 'A':
