4.2 stumble on accelleration, no trouble codes
Hi everyone, Ive got a 4.2 in my truck that stumbles and feels like it's going to die when you give it gas from a stop. It doesn't do it all the time, and does not put check engine light, or show any codes. plugs/wires/coilpack/DPFE have been replaced. MAF, IAC were cleaned. Fuel filter is new, fuel pressure is good, Vacuum is good. Truck is scary to pull out into traffic with. Any Ideas? Thanks!
Without a code, this can be tough to nail down. However, never assume that new parts that you installed are good. Even though you cleaned them, you can't assume the IAC and MAF are good. The EGR valve itself could be sticking. The EGR vacuum solenoid may be bad. Some of these things can be tested with a reasonable assortment of tools and test equipment and a factory service manual. It could be the TPS.
Wow, wish I would have known that when I did mine. I just changed my plugs again a couple weekends ago but didnt do the wires this time, runs better but if I knew I could get them for that price I would have done the wires again.
The intake leak in my case came just a bit later.
Did the plenum gaskets/isolaters (P0174 code lean). fixed the IMRC links at the same time because the bushings were gone and rods out. got no IMRC codes though...
Plugs and wires are new motorcraft parts, Ran Techron thru the motor, fuel pressure is in spec. At this point, I think the gas in the tank may be bad (Goddamn E10 gasohol).
The truck sits a lot and the gas may have seperated or gone moldy or whatever the crap does.
How do I drain the tank on this truck?
