4.2 Locked up!
I gave it 1 last try last night, removed fan and got a big socket on the crank bolt, braker bar, cheater bar, it wont move! At least I got the bolt out.
I'm about to start dis-assembling, getting those heads off would give me alot of room, then I could also lube and tap the pistons.
I have never pulled a engine out with the converter attached, dont know what to expect!
(see if this works)
http://www.flickr.com/photos/1813031...in/photostream
dis-assembling the 99 4.2
I got a good start yesterday! More today! 107 yesterday another 107 degrees coming today!
missing
fan
power steering bracket
upper intake
raditor hoses
heater hosed
some vac lines
coil
spark wires
http://www.flickr.com/photos/1813031...n/photostream/
missing
fan
upper intake
raditor hoses
heater hosed
some vac lines
coil
spark wires
Todays progress and other pictures of the head and lower intake, you gatta see this!
http://www.flickr.com/photos/1813031...57630755277554
Do more tommoro! 108 today (that sucks)
I got alittle more done! Pully the harmonic balancer, starter, exhause pipes, moter mounts threw bolts
One of the torq converter nuts is in doable range of getting to! 3 to go!
I did read where a guy stuck a box end skinny whench between the rear engine schild and the flex plate and got to the bolts. Anyone know anything about this practice! This could open some doors for guys with stuck engines.
Afew new pictures are up:
http://www.flickr.com/photos/18130316@N07/7663869674/
After that we placed the block on a eng stand and removed the oil pan. Expected to see something twisted up or broken! But see nothing apparent.
Oil pump screen was not clogged but did have a few piece's of crud on it!
We did find metal shaving in the bottom of oil pan, some were large!
picture are up!
Have not removed heads as of yet!
That's where i'm at now!
1 of the 4 main bearing was shot (didn't spin), took all the pistons out today, all the bearings are shot, lools like some moved within the rod!
Now the engine rotates! lol
I really dont know what I should expect when it comes to machine shop work are the cost.
Anyone help with this!!!
New pictures are up:
I think I found the problem tonight! 3 of the teeth on the oil pump drive gear are stripped, all the gears are worn sharp.
I had to use a puller to remove the cam gear, it does not slide off! LOL
If you ever have the timing cover off for any reason this would be something to look for!
I'm not quite sure what your refering to. If its the large washer that the bolt go's thru, then to the center of the crank, I have it!
Got the cam and balance shaft out now, it looks rough!
