Dyno Pulls with AFE stg 2 Intake and SCT 93 octane tune
Ok let me start....These Dynos were done on dynojet Dyno. On the same day, intakes were swapped out in between runs as well as the tune was changed between runs.
I was surprised by the results and still not real sure what to say with regards to the actual numbers. My truck would kick out on the stock tune at 4750 rpm, it did that on 4 different pulls in 4th gear. Not sure if it was a speed limiter or traction control. The Hp was still climbing so Id be curious to see if the results would have been different for the intake in the higher rpms.
I still love my AFE intake and think it allows the truck to breathe a lot better, but doesn't show the gains I thought. It was also very difficult to start pulls lower then 2000-2500, the truck would again to some odd things.
But these results show some interesting things.
Each graph is labels for each run with a combined graph at the end.
maybe
I would also like to know if the SCT flash had accounted for the CAI durring the dyno run. might have gotten more whp & tq if it was tunned for it.
Either way
I've been emailing a performance shop close to home and one thing he pretty much made clear....a CAI is not worth the money you spend on them,basically don't bother.
I'm leaning towards the SCT,but will probably get a few custom tunes done....it all costs unfortunately!
Now I just gotta figure out if I really want to keep the 4" cat back back on...
I wonder what independent synthetic cone filters run independently on their own to a turbo with a ballance tube would add? Still believe there is a hang up with the 360 degree big and smaller 90 degree elbow of the stock tubes connected to the turbos? Air does some wierd things when it divides flow, slams into the wall/looses enertia changing direction slightly, in different sizes of the tubes?
