where the HECK is that PCV????
Man, I have read all the posts on where this should be, but I still cannot find it. I have a 2003 4.2L.
The only thing the passenger side valve cover is a vacuum connection leading to the throttle body inlet. Its straight thru....no valve.
On the driver side another vacuum tube runs to the intake tube. It also has no valve.
There is nothing I can see on the back of the intake manifold except about 1/2 inch of clearance with the firewall. I really find it hard to believe that the PCV would be put back there where you absolutely cannot reach it.
The emissions sticker shows a PCV connected to manifold vacuum at the front of the vehicle just to the passenger side of the EGR. I simply cannot find it. I've changed camshafts before, so I'm not ignorant about engines. Why can't I find a friggin PCV?????????
Guys, The PCV Valve is on the right side of the intake manifold, just behind the throttle body. Follow the hose from the Valve Cover. there is a rubber 45 degree elbow, that connects it to the manifold. the pipe that it is connected too, that also has two water lines going to it IS THE PCV VALVE. the picture shown on the ford parts site is a generic one, and the parts houses other than the dealer will all give you the wrong one.
If I remember the part is EV256, but just go to the dealer and buy what they show listed. When you see it, you will know exactly where it goes. The o-ring around it is probrably leaking which constantly throws 02 sensor codes, and it will fix it.
Been There, chased that, figured it out.
Brad
Brad
Thanks Brad, I was just about to give up looking for the PCV valve and change the port gaskets and isolation bolts. I've been getting those #!*% codes constantly for a long time. Someone had told me that the 2003's didn't have a PCV valve and that didn't make sense to me either. I may still have to do the gaskets and bolts, but checking the PCV is certainly the right next step. I'll let you know how it goes.
Brad
Brad
Be Aware!
Brad
Brad
Before buying a EV256, look at the unit. It may be just a vacuum port with heating lines. My 2001 4.2L does NOT have a pcv there, just:
9A474 Connector - Vacuum Tube **3Z-9A474-AA For Valve cover mounted PCV4.2 6 Cyl, Ford 150 Series
So, Anyone know the part number of just the O ring?
