List of trouble codes for the 4.2L V6
Old 10-22-2006, 09:41 PM
Peacemaker's Avatar
DTC 001
DTC 002
DTC 003
DTC B0012, B0013, B0014, B0016, B0017, or B0018
Right Front/Passenger Frontal Deployment Loop Circuit
DTC B0022, B0024, B0026, B0042, B0043, or B0044
Left Front/Driver Frontal Deployment Loop Circuit
DTC B0028, B0029, or B0030
Right Front/Driver Side Deployment Loop Circuit
DTC B0040, B0041, or B0045
Left Front/Driver Side Deployment Loop Circuit
DTC B0051
Deployment Commanded
DTC B0053
Deployment Commanded with Loop Malfunctions Present
DTC B0077, B0078, B0079, B0080, B0081, or B0082
Side Impact Sensor (SIS) Circuit
DTC B0100, B0101, B0102, B0103, B0104, or B0105
Electronic Frontal Sensor Circuit
DTC B0145, B0428, or B3531
Auxiliary HAVC Actuator Circuit
DTC B0159 or B0164
Air Temperature Sensor Circuit
DTC B0174, B0179, B0510, or B0515
Discharge Air Temperature Sensor Circuit
DTC B0183 or B0188
Sunload Sensor Circuit
DTC B0229, B0414, B0424, B3761, or B3770
HVAC Actuator Circuit
DTC B0248, B0263, B0268, B0408, or B0418
DTC B0248, B0263, B0408, or B0418
DTC B0283
Electric Rear Defrost Circuit
DTC B0414, B0424, B3761, or B3770
DTC B0540
Speedometer Circuit
DTC B0560
Tachometer Circuit
DTC B0770
All Wheel Drive (AWD) Indicator Circuit
DTC B0775
Four Wheel Drive High Range (4HI) Indicator Circuit
DTC B0780
Four Wheel Drive Low Range (4LO) Indicator Circuit
DTC B0785
Two Wheel Drive High Range (2HI) Indicator Circuit
DTC B0790
Transfer Case Neutral Indicator Circuit
DTC B0951
Dimming Circuit
DTC B1000
ECU Malfunction
DTC B1001
Option Configuration Error
DTC B1004
Keep Alive Memory (KAM) Reset
DTC B1007
Electronic Control Unit (ECU) Performance
DTC B1009
EEPROM Checksum Error
DTC B1017
Output Driver Module (ODM) 1 Performance
DTC B1023
Integral Switch Performance
DTC B1372
Device Ignition 1 (ON and START) Circuit Low
DTC B1375
Device Ignition 3 (ON) Circuit
DTC B1420
Device Voltage
DTC B1440
Power Mode Master Input Circuits Mismatch
DTC B1480
Battery Rundown Protection Circuit Malf
DTC B1550
Mirror Left Front or Right Front Select Switch Circuit
DTC B1720
Mirror Up and Down Control Switch Circuit
DTC B1721
Mirror Left and Right Control Switch Circuit
DTC B1723
Mirror Motor Control Circuit 1 Performance
DTC B1724
Mirror Motor Control Circuit 2 Performance
DTC B1735, B1740, B1745, B1750, B1755, B1760, B1815, or B1820
Power Seat Switch Circuit
DTC B1825, B1850, B1860, B2355, B2365, or B2375
Seat Position Sensor Circuit
DTC B1830, B1835, B1840, B1845, B2075, B2080, B2085, B2090, or B3905
Lumbar Switch Control Circuit
DTC B2425 or B2430
Seat Heater Circuit
DTC B2435 or B2440
Seat Back Heater Sensor
DTC B2455
Cellular Phone Microphone Circuit
DTC B2470
Cellular Phone Antenna Circuit
DTC B2476
Cellular Phone Select Service Switch Malfunction
DTC B2482
Cellular Phone Select Service Switch Range/Performance
DTC B2483 or B2484
Global Positioning System (GPS) Sensor Circuit
DTC B2527
Front Fog Lamp Circuit Low
DTC B2530
Front Foglamps Control Circuit
DTC B2540
Rear Foglamps Control Circuit
DTC B2550
Backup Lamps Control Circuit
DTC B2575
Headlamp Control Circuit
DTC B2580
Headlamp High Beam Control Circuit
DTC B2585
Parklamp Control Circuit Malfunction
DTC B2610
Passenger Compartment Dimming 1 Circuit
DTC B2615
Passenger Compartment Dimming 2 Circuit
Old 10-22-2006, 09:43 PM
Peacemaker's Avatar
DTC B2620
Display Dimming Input Circuit
DTC B2625
Display Dimming Pulse Width Modulation (PWM) Output Circuit
DTC B2645
Ambient Light Sensor Circuit
DTC B2697
Headlamp Washer Request Circuit
DTC B2725
ATC Mode Switch Circuit Malfunction
DTC B2734
Control Module Internal Performance
DTC B2815
Steering Wheel Controls Illegal Resistance Value
DTC B2947
Security System Sensor Power CKT Low
DTC B2948
Security System Sensor Power CKT High
DTC B2957
Security System Sensor Data Circuit Low
DTC B2958
Security System Sensor Data Circuit High
DTC B2960
Sec Sys Sensor Data Incorrect but Valid
DTC B2961
Key In Ignition Circuit Malfunction
DTC B3031
Key Decoder Device in Assem Learn Mode
DTC B3055
Key Not Present
DTC B3060
Unprogrammed Transponder Identification Code Received
DTC B3801
Passenger Compartment Lamp Request Circuit
DTC B3802
Parklamps Request Circuit
DTC B3808
Rear Door Lock Relay Circuit
DTC B3809
Rear Door Unlock Relay Circuit
DTC B3810 or B3811
Washer Relay Circuit
DTC B3819
Left Rear Power Window Up Relay Circuit
DTC B3820
Left Rear Power Window Down Relay Circuit
DTC B3821
Window Lockout Circuit Low
DTC B3822
Right Rear Power Window Up Relay Circuit
DTC B3823
Right Rear Power Window Down Relay Circuit
DTC B3824
DTC B3935
Transponder Authentication Error
DTC C0221-C0227
Front Wheel Speed Sensor Circuit
DTC C0229
Drop Out of Front Wheel Speed Signals
DTC C0235-C0237or P0609
Rear Wheel Speed Sensor Circuit
DTC C0238
Wheel Speed Mismatch
DTC C0241-C0254
EBCM Control Valve Circuit
DTC C0265 or C0266
EBCM Relay Circuit
DTC C0267 or C0268
Pump Motor Circuit Open/Shorted
DTC C0269 or C0274
Excessive Dump/Isolation Time
DTC C0271-C0273, C0284
EBCM Malfunction
DTC C0279
Powertrain Configuration Not Valid
DTC C0281
Brake Switch Circuit
DTC C0283
Traction Switch Shorted to Ground
DTC C0287, P1644, or P1689
Delivered Torque Circuit
DTC C0290 or C0292
Lost Communications With PCM
DTC C0291
Lost Communications With BCM
DTC C0297
Powertrain Configuration Data Not Received
DTC C0298 or P1571
Powertrain Indicated Traction Control Malfunction
DTC C0300
Rear Speed Sensor Malfunction
DTC C0305
Front Speed Sensor Malfunction
DTC C0306
Motor A or B Circuit
DTC C0321
Transfer Case Lock Circuit
DTC C0327
Encoder Circuit Malfunction
DTC C0359
Four Wheel Drive Low Range (4LO) Discrete Output Circuit
DTC C0374
General System Malfunction
DTC C0379
Front Axle System
DTC C0550
ECU Malfunction
DTC P0101
Mass Air Flow (MAF) Sensor Performance
DTC P0102
Mass Air Flow (MAF) Sensor Circuit Low Frequency
DTC P0103
Mass Air Flow (MAF) Sensor Circuit High Frequency
DTC P0106
Manifold Absolute Pressure (MAP) Sensor Performance
DTC P0107
Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage
DTC P0108
Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage
DTC P0112
Intake Air Temperature (IAT) Sensor Circuit Low Voltage
DTC P0113
Intake Air Temperature (IAT) Sensor Circuit High Voltage
DTC P0116
Engine Coolant Temperature (ECT) Sensor Performance
DTC P0117
Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage
DTC P0118
Engine Coolant Temperature (ECT) Sensor Circuit High Voltage
DTC P0120
Throttle Position (TP) Sensor 1 Circuit
DTC P0125
Engine Coolant Temperature (ECT) Insufficient for Closed Loop Fuel Control
DTC P0128
Engine Coolant Temperature (ECT) Below Thermostat Regulating Temperature
DTC P0131 or P0151
HO2S Circuit Low Voltage
DTC P0132 or P0152
HO2S Circuit High Voltage
DTC P0133 or P0153
HO2S Slow Response
DTC P0134 or P0154
HO2S Circuit Insufficient Activity
DTC P0135, P0141, P0155, or P0161
HO2S Heater Performance
DTC P0137 or P0157
DTC P0138 or P0158
DTC P0140 or P0160
DTC P0171 or P0174
Fuel Trim System Lean
DTC P0172 or P0175
Fuel Trim System Rich
DTC P0200
Injector Control Circuit
DTC P0218
Transmission Fluid Overtemperature
DTC P0220
Throttle Position (TP) Sensor 2 Circuit
DTC P0230
Fuel Pump Relay Control Circuit
DTC P0300
Engine Misfire Detected
DTC P0315
Crankshaft Position (CKP) System Variation Not Learned
DTC P0325
Knock Sensor Module Performance
DTC P0327 or P0332
Knock Sensor Circuit
Old 10-22-2006, 09:44 PM
Peacemaker's Avatar
DTC P0335
Crankshaft Position (CKP) Sensor Circuit
DTC P0336
Crankshaft Position (CKP) Sensor Performance
DTC P0341
Camshaft Position (CMP) Sensor Performance
DTC P0342
Camshaft Position (CMP) Sensor Circuit Low Voltage
DTC P0343
Camshaft Position (CMP) Sensor Circuit High Voltage
DTC P0351-P0358
Ignition Coil Control Circuit
DTC P0401-P0402
Insufficient/Excessive EGR Flow
DTC P0420 or P0430
Catalyst System Low Efficiency
DTC P0442
Evaporative Emission (EVAP) System Small Leak Detected
DTC P0443
Evaporative Emission (EVAP) Purge Solenoid Control Circuit
DTC P0446
Evaporative Emission (EVAP) Vent System Performance
DTC P0449
Evaporative Emission (EVAP) Vent Solenoid Control Circuit
DTC P0452
Fuel Tank Pressure Sensor Circuit Low Voltage
DTC P0453
Fuel Tank Pressure Sensor Circuit High Voltage
DTC P0455
Evaporative Emission (EVAP) System Large Leak Detected
DTC P0461
Fuel Level Sensor Performance
DTC P0462
Fuel Level Sensor Circuit Low Voltage
DTC P0463
Fuel Level Sensor Circuit High Voltage
DTC P0480
Cooling Fan Relay Control Circuit
DTC P0483 or P0493
Cooling Fan System
DTC P0495
Cooling Fan Speed High
DTC P0496
Evaporative Emission (EVAP) System Flow During Non-Purge
DTC P0502
Vehicle Speed Sensor (VSS) Circuit Low Input
DTC P0503
Vehicle Speed Sensor (VSS) Circuit Intermittent
DTC P0506
Idle Speed Low
DTC P0507
Idle Speed High
DTC P0522
Engine Oil Pressure (EOP) Switch Circuit Low Voltage
DTC P0523
Engine Oil Pressure (EOP) Sensor Circuit High Voltage
DTC P0526
Cooling Fan Speed Sensor Circuit
DTC P0530
Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit
DTC P0562
System Voltage Low
DTC P0563
System Voltage High
DTC P0567
Cruise Control Resume Switch Circuit
DTC P0568
Cruise Control Set Switch Circuit
DTC P0601-P0607, P1600, P1621, P1627, P1680, P1681, P1683, or P2610
ECU Malfunction
DTC P0608
Vehicle Speed Output Circuit
DTC P0621
Generator L-Terminal Circuit
DTC P0622
Generator F-Terminal Circuit
DTC P0641
5 Volt Reference 1 Circuit
DTC P0650
Malfunction Indicator Lamp (MIL) Control Circuit
DTC P0651
5 Volt Reference 2 Circuit
DTC P0654
Engine Speed Output Circuit
DTC P0705
Transmission Range (TR) Switch Circuit
DTC P0706
Transmission Range (TR) Switch Performance
DTC P0711
TFT Sensor Circuit Range/Performance
DTC P0712
Transmission Fluid Temperature (TFT) Sensor Circuit Low Input
DTC P0713
Transmission Fluid Temperature (TFT) Sensor Circuit High Input
DTC P0719
Brake Switch Circuit Low Input
DTC P0724
Brake Switch Circuit High Input
DTC P0740
TCC Enable Solenoid Circuit Electrical
DTC P0741
Torque Converter Clutch (TCC) System-Stuck Off
DTC P0742
TCC System Stuck On
DTC P0748
Pressure Control Solenoid Circuit Electrical
DTC P0751
1-2 Shift Solenoid Valve Performance
DTC P0752
1-2 Shift Solenoid (SS) Valve Performance - No Second Or Third Gear
DTC P0753
1-2 Shift Solenoid Circuit Electrical
DTC P0756
2-3 Shift Solenoid Valve Performance
DTC P0757
2-3 Shift Solenoid (SS) Valve Performance - No Third Or Fourth Gear
DTC P0758
2-3 Shift Solenoid Circuit Electrical
DTC P0785
3-2 Shift Solenoid Circuit Electrical
DTC P0894
Transmission Component Slipping
DTC P1106
Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage
DTC P1107
Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent Low Voltage
DTC P1111
Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage
DTC P1112
Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage
DTC P1114
Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage
DTC P1115
Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage
DTC P1125
Accelerator Pedal Position (APP) System
DTC P1133 or P1153
HO2S Insufficient Switching
DTC P1134
HO2S Transition Time Ratio Sensor 1
DTC P1137
HO2S Circuit Low Voltage During Power Enrichment Sensor 2
DTC P1138
HO2S Circuit High Voltage During Decel Fuel Cut-Off (DFCO) Sensor 2
DTC P1171
Fuel System Lean During Acceleration
DTC P1258
Engine Coolant Overtemperature - Protection Mode Active
DTC P1380
Misfire Detected - Rough Road Data Not Available
DTC P1381
Misfire Detected - No Communication with Brake Control Module
DTC P1481
DTC P1482
Cooling Fan Speed Output Circuit
DTC P1484
Cooling Fan System Performance
DTC P1514
Throttle Body Performance
DTC P1515
Control Module Throttle Actuator Position Performance
DTC P1516
Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance
DTC P1518
Throttle Actuator Control (TAC) Module Serial Data Circuit
DTC P1574
Stoplamp Switch Circuit
Old 10-22-2006, 09:46 PM
Peacemaker's Avatar
DTC P1626
Theft Deterrent Fuel Enable Signal Not Received
DTC P1630
Theft Deterrent Learn Mode Active
DTC P1631
Theft Deterrent Start Enable Signal Not Correct
DTC P1632
Theft Deterrent Start Disable Signal Received
DTC P1637
DTC P1638
DTC P1810
TFP Valve Position Switch Circuit
DTC P1860
TCC PWM Solenoid Circuit Electrical
DTC P1870
DTC P1875
Four Wheel Drive (4WD) Low Switch Circuit
DTC P2108
Throttle Actuator Control (TAC) Module Performance
DTC P2120
Accelerator Pedal Position (APP) Sensor 1 Circuit
DTC P2121
Accelerator Pedal Position (APP) Sensor 1 Performance
DTC P2125
Accelerator Pedal Position (APP) Sensor 2 Circuit
DTC P2135
Throttle Position (TP) Sensor 1-2 Correlation
DTC U1000 and U1255
Class 2 Communication Malfunction
DTC U1001-U1254
Lost Communication with XXX
DTC U1300, U1301, or U1305
Class 2 Data Link Shorted
DTC U1500
Inter-device Dedicated Bus 1
Old 11-20-2006, 05:11 PM
BlueOvalFitter's Avatar
Question
What about codes P1537 and P1538? Those were the codes mine threw when the IMRC accuators went bad.
Old 11-20-2006, 06:50 PM
Peacemaker's Avatar
I got that list from another website, so I'm not sure. Just add those two to the list I guess.
Old 11-22-2006, 09:04 AM
Labnerd's Avatar
Here are more useful links:
http://www.fordfuelinjection.com/
Click on the items in the navigation bar to the right
Troubles codes
http://www.troublecodes.net/Ford/
Trouble codes
http://www.obd-codes.com/trouble_codes/ford/
OBDII theory and operation
http://www.motorcraftservice.com/vdi...tsid=diagsheet
Recalls and TSBs
http://www.alldata.com/recalls/index.html
Old 12-21-2007, 02:35 AM
Old 12-29-2007, 04:48 PM
Raptor05121's Avatar
No P2042? That's what I'm getting. AutoZone guy says "bank 1 misfire" and dad suggests its a loose sparkplug wire, I have no idea.
Old 12-30-2007, 12:57 AM
glc is online now
P2042, Reductant Temperature Sensor Circuit.
Not ignition related. No idea what that is exactly though.
Old 12-30-2007, 01:57 AM
Yeah, it is not ignition related at all...
It sounds as if it is emissions related. I think it has something to do with NOx reduction. Not totally sure though.
Old 12-30-2007, 05:43 AM
jbrew's Avatar
Strange code ehhh..
I would reboot , it might have been something in the gas...
http://www.pacificp.com/index.php?main_page=page_10
Old 12-30-2007, 11:51 AM
glc is online now
NOx reduction is done by EGR and the cats.
Old 01-26-2008, 11:52 PM
P0300
I'm getting P0301, I'm guessing misfire in a specific cylinder?
I just cleared it and will change the plugs next month.
Old 04-11-2008, 02:12 PM
4.2L_Guy's Avatar
man wish i new what you guys were talking about... i mean i no what your tlkin about... but how do you find all these out (i no autozone does it)... and how would you go about fixin them?
Quick Reply: List of trouble codes for the 4.2L V6
