Flashing overdrive "off" light, 2000 F150 4.2L auto - F150online Forums
Old 05-01-2005, 07:20 PM
Got strange flashing light (no not UFO!). Overdrive "off" light in gear selection lever is flashing. Flashing is at a rate of 1 flash/second. Not random. Is this a message from the Ford great beyond? What gives? Is it a trouble code of some sort? Hope someone can explain this. Thanks in advance, Goballistic
Old 05-01-2005, 07:27 PM
Certified Goat Breeder
There are 115 possibilities.
Too many to type here.
Using the SEARCH feature:
Word or Phrase = 'flashing'
Forum = Transmissions
Old 05-02-2005, 01:54 AM
Thanks Raoul
After searching as you suggested the tales of doom & gloom regarding the "Flashing light" are numerous. I haven't had this issue (3 years of ownership) until now. For the record, I installed two pre catalitic HO2 sensors today. The neg battery connection was removed prior to doing work and was disconnected for 2/3 hrs. This cleared all computer memory-codes including Keep Alive Memory. Either the clearing of the ODBII caused this to occur (start up diognostic?, Glitch?) or the problem has existed since I purchased the truck. I soppose it is possible (upon reboot) the OBD found the error. It's also possible this happened to the previous owner and I was not aware of it (since the flashing stops the first time vehicle is turned off). If the problem was pre existing over the 3 years I've owned the truck shoulden't the tranny have died! The trans shifts normally and overall trans performance has not changed in the time I've owned the vehicle. I hesitste to grant the Ford service dept. access to my wallet unless it is absolutely necessary! Raoul, let me know what you think. All comments are welcome so lets hear it!
Goballistic
Old 05-04-2005, 01:14 PM
It would be worth having the trouble codes scanned. Even if the dealer gave you a heads up on what the problem is, your're a step ahead.
Related Topics
Thread
Forum
Replies
Last Post
tsteve25
12-07-2015 09:20 AM
LUCC
Chips, Tuners & Programming
5
09-26-2015 12:41 PM
Cantputt
07-31-2015 11:19 AM
Leowis1
07-18-2015 01:09 AM
peremcguire
Transmissions
6
07-12-2015 12:41 AM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
