Fuel Filter Change
Fuel Filter Change
I want to change the fuel filter on my 4.2 2000 F150. Well I found where it is located. However, I cannot understand how to remove the fuel line tube connections on either end of the filter. There are metal clamps at the end of the tubes that are stumping me.
Has anyone removed these fuel line tubes and replaced them? Any help would be appreciated.
You need a special tool.They sell them at any parts store.There is the plastic type,which I use,and the metal type.Just ask parts dude which of the two he stocks.Then,remove the clips and slide the tool in the fitting,which releases the clamps on the fuel filter.You might need to tug on the connection a bit as you insert the tool.They can be stubborn! Spray some WD-40 in each one before removing.
Originally posted by MICHAELMEYERS31
I hate to sound stupid, but what does a fuel rail look like and where is it located? Thanks for your help.
The fuel rail is a silver tube that connects to the fuel injectors.The fuel injectors are seated into the lower intake. Look between your valve covers and you will see the fuel rail sitting on the injectors. I think the schrader valve is on the drivers side fuel rail.
Yep, driver's side fuel rail. Just look right over top your driver side valve cover for a silver tube. The valve is near the middle of the rail. As was mentioned, it looks like a valve stem on a wheel. What I did was remove the cap and use a small phillips screwdriver to push on the needle in the valve to relieve the fuel pressure. But be ready for fuel to spray up out of the valve. Have a rag handy to hold over it while you do this. Then just do what was said above to change the fuel filter.
WARNING! DO NOT ATTEMPT THIS ON A HOT ENGINE!
Let it cool down about an hour before you do this.
Thanks guys for your help. It was quite simple. I only had problems getting one side off, seemed to be stuck. But I did manage to find a method to taking these off. Thanks again.
I'm not recommending this. I am running the factory filter at 181K miles. My belief is that if it will still flow the max required fuel (wide open at high RPMs), it doesn't need replaced. I test this periodically but hooking up my scan tool, graphing either one of the pre-cat O2 sensors, and running wide open through 3500 RPMs. This does two things, first is it demands the maximum fuel flow from the pump and the filter. Second, it forces open loop WOT enrichment which should drive the O2 sensors high. If the O2 sensor goes high and stays there, the pump and filter are fine. If they don't, I'll change my filter.
This may overlook things like the filter's ability to absorb dirt or water or other things I haven't thought of, but it's what I've relied on so far. I'd be interested if someone knows why I should do it different.
