Home Discussion Forums Photo Gallery Product Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Photo Galleries Ford Truck News Event Calendar Advertise with us
F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain (OEM) > V-6 Engine
Thread Tools Display Modes
Old 09-15-2008, 06:02 PM
I Need some help....
I have a 2001 f150 4.2 and I have noticed that as i am starting it up the battery seems to drain or rather the truck slow cranks. Now here lately the battery would be dead completely and I would have to push start the truck. I am thinking I should replace the battery.
Old 09-16-2008, 10:05 AM
glc glc is offline
Vehicle: 2003 Ford F150
Most auto parts stores can load test a battery and test a charging system. Take advantage of the free service.
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 10-02-2008, 12:08 PM
Vehicle: 1998 Ford F150
ture dat glc!!!
Nicknames
Spool Time
Bud
Bigdog
Old 10-02-2008, 12:47 PM
Vehicle: 2002 Ford F-150
Quote:
I know that auto stores will do this for free, but I would get a cheap multi-meter and test the stuff myself, I've had auto store guys ruin my alternator that was being tested because they connected it wrong.
with a multi meter set it to the DC side in the 20 range, and touch the prongs to the battery. Have someone start the truck (or try) if you see a drop of more than a couple volts, your battery is tanked. If the battery holds the load and starts, then leave multi-meter connected and if while running your get >12 and it is discharging, your alternator is shot.
I believe it is your battery, if you were having a charging issue you should bet the bettery on in your dash.
FX
Old 10-02-2008, 03:30 PM
glc glc is offline
With the truck running and all accessories off, the voltage across the battery should be at least 13.5 volts, 14 is more like it. Anything less and you have a weak alternator. A fully charged battery will be at least 12.0 volts.
Old 10-02-2008, 04:23 PM
Quote:
>=less than, if it reads 14 his alternator is fine. Are we saying the same thing?
Old 10-02-2008, 05:33 PM
glc glc is offline
Yup. 14 volts at idle is fine. You said 12, not 14. I *think* the official specs are something like 13.8 to 14.4.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
F150Online.com and InternetBrands, Inc. are not affiliated with the Ford Motor Company
