Home Discussion Forums Photo Gallery Product Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Photo Galleries Ford Truck News Event Calendar Advertise with us
F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain (OEM) > V-6 Engine
Thread Tools Display Modes
Old 07-01-2008, 10:52 PM
98 will idle fine, won't rev-up..
My Beautiful truck is down again. This time it started up fine, I let it warm up. Dropped it into Drive,and gave it some gas...and it just sputtered.
It will start up and idle fine...even in Park it will not take any gas without sputtering out....
The check engine light is on, but I don't have a scanner...Advance auto will do it for free..but I'll never get it there.
Has anyone ever run into this? It's to nice of a truck to hate
Old 07-02-2008, 01:36 PM
glc glc is offline
Vehicle: 2003 Ford F150
Some parts stores will let you "borrow" a code scanner - leave your credit card as security, bring it back in a reasonable period of time, no charge. Others may let you buy one and bring it back for a refund same day.
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 07-02-2008, 01:40 PM
Vehicle: 1999 Ford F150
glc.... doesnt sound like hes runnin rich? maybe you have a vacuum leak or a posibly a hole in the intake somewhere?
SOUTHERN PRIDE TILL I DIE
Old 07-02-2008, 01:54 PM
Vehicle: 2003 Ford
Quote:
a vacuum leak/hole in the intake will usually cause you to run lean.
if unmetered air is making its way into the intake it'll be lean.
as far as being too rich thats a possibility but rich usually isnt caused by a vacuum leak (that i know of)
hopefullly he can get a scanner and tell us what it reports.
Old 07-02-2008, 01:59 PM
gotcha so since there more air getting let in will cause the lean condition?
so waht can cause a rich condition? for future reference?
Old 07-02-2008, 02:34 PM
Barrowed a scanner...ended up with some shift selanoid codes..and torque convertor circuit...hopefully it's just an electrical problem within the trans.
Only thing is, why won't it rev up in park?
Old 07-02-2008, 09:19 PM
The Transmission guy call's me and says it started bringing up all these codes at once, and he couldn't figure why....Then He said he found a wire harness with a wire...wires... chewd or cut thru...He fixed up the wires in the harness and said it was running like a top. Said it even made the engine run better....
Anyone know anything... about something like that...What kind of wire could this be? I'm thinking chimpmonks...or rabbits..
Old 07-02-2008, 10:16 PM
Vehicle: 1998 Ford F-150
Do you have a enclosed garage or something? How would a rabbit or something make it up in the drivetrain like that unless it was one of those wires coming out of it.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
F150Online.com and InternetBrands, Inc. are not affiliated with the Ford Motor Company
