Quote:
<font face="Verdana, Arial" size="2">Originally posted by sleepiweasel:
Does anyone know where the VSS speed sensor is on a 98 f-150? And what color it is? thnxs</font>
If it's the same as my '97, it's on the end of the transmission housing just before the yoke to the driveshaft. Kinda on top. It's held on with just one nut. There will be a small rubber "O" ring to seal it on the inside. Don't damage it. The gear should should just pull off and you can put your new one on. I did it in about two minutes. I didn't disconnect the wire harness to it or disconnect the battery.
1997 F150 4x4 Off Road, SuperCab, Short Box, 5.4, Royal Blue/Silver, K&N, Gibson SS, LT265/75/16 Wild Country APT's
