F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 06-04-2001, 02:23 AM
Registered User
Vehicle: 2004 Ford F-150
Send a message via AIM to 5.4lariat
Angry O/D Light won't stop flashing!!!!
Ok, here is the deal.
I looked down to see weather or not I was in O/D while I was pulling a trailer, and there she was just a flashing. However the tc will lock in into O/D and drive fine, but it wont stop flashing, and when I decelerate at about 15-20mph, I get that tranny clang that DODGE is known for. (NOT HAPPY)
So if anybody knows why this is happening, please drop me a line, not sure if it is a sensor of what!!??
'99 Lariat
5.4
TBI spacer
Flo-Pro (running open dumps, true dual)
K&N G-2
Xenon driving & fog
3k lb helper springs
Rancho 9000 all around
And big BFG's
Old 06-04-2001, 02:38 AM
Vehicle: 1997 Ford F150
Send a message via AIM to King James
Post
Do a search for o/d light flashing, light flashing, o/d light, etc. Mine flashes every once in a while also. Having it scanned for codes tomorrow. I don't haul anything and I haven't noticed any problems. My speedo starts going crazy after the light is flashing for about 15 minutes. I have a topic in computer chips called "tranny problems caused by superchip?"
The truck:
Teal 1997 XLT flareside with 4.6L, auto tranny, electronic shift on the fly, 3.55LS and 4x4 ORP.
Performance mods:
Gen. 2 K&N FIPK
Superchip(removed until further notice)
True dual exhaust exiting out the back
2.5" pipe with 18" glasspacks and 18"x4" round chrome slash cut tips
Appearance:
White face gauges
Euro clear corners
01L headlights
Covercraft tonneau cover
Billet pedals
16" ModernŠ wheels
265/75r16 Wild Country Radial TXR tires
Factory tinted rear windows
Bug deflector
Euro clear corners
Sound system:
Clarion ADX5655z Double Din Cassette & CD
4 Pioneer TS-A6865 speakers
Other:
Bedliner
Bulldog keyless entry/remote start
n6260k@cs.com
<A HREF="http://www.f150world.com/v8speeddemon" TARGET=_blank> </A>
Old 06-04-2001, 02:13 PM
Goat Herder Extraordinaire
Vehicle: 1999 Ford F150
Post
YIKES! I thought it indicated a 'new best' on my ET!
1999 Ford F150 Lariat RegCab 2WD shortbed 5.4L 3.55LS Towpkg Line-X
15.714@85.21
Old 06-05-2001, 01:29 AM
Vehicle: 2002 Ford E350
Post
A flashing OD light means SOMETHING is wrong with the transmission system.
The transmission system includes the transmission, torque converter, wiring, sensors, etc. To be able to tell you what is causing the light to flash you must have the code that is set. Something is not as it should be.
Mark
Old 06-05-2001, 05:37 AM
Registered User
Post
Quote:
<font face="Verdana, Arial" size="2">Originally posted by Raoul:
</font>
I wish that was it, but I'm not that lucky!!
Old 06-05-2001, 10:12 AM
Exclamation
I had the same problem with my truck around 19000 miles, that damed light started flashing and would not go away, although mine would not go into 4th gear and started shifting strange. At that point I had not towed or hauled anything really. Took it in to the dealer and found it is a known problem on later F-Series trucks mine was a valve in the trans was not working properly. Also I have heard other people have problems with the trans failing if it is serviced at Fords regular schedule has anyone else heard or able to confirm this?
98 F150 XLT s/c s/b
Stock 4.6 3.55
255/70r16
Old 06-05-2001, 12:58 PM
Registered User
Post
Quote:
<font face="Verdana, Arial" size="2">Originally posted by speedy46:
</font>
I have heard that changing you tranny fluid will kill your tranny too, but then what the heck are you supposed to do, time for a 5 speed, LOL.
Old 06-05-2001, 07:08 PM
Vehicle: 2000 Ford F-150
Lightbulb
Howdy All,
As Mark has stated previously. If your OD cancel light starts flashing you need to have your codes read. Depending upon which code is present, it will help the Technician to diagnose what is happening with the powertrain.
Depending on the severity of the condition, you may experience strange shifting of your trans. These transmissions have a failsafe mode that attempt to protect the transmission to allow the vehicle to be driven to a repair facility, hopefully before they cannibalize themselves.
The best thing you can do for your trans is to change the fluid on a regular basis. Have the pan dropped, a new Ford filter installed and drain the converter.
2000 F-150 Lariat, Flareside, Black, SC, FOxFO, 5.4L, 4R70W TranZ, 3.55 Limited Slip Rear Axle, Garmin Street Pilot Color GPS, Bed Rug, ExTang Saber Tonno, CatchALL Floor Mat's, VentShade Visors, Limo BLaCK Tint'd Windows, PIAA Platinum Super White Headlight Bulbs with XTra Technology, FLoWMaSTer 40 Series MuFF, Mobil 1 5W-30 and Motorcraft 820-S Filter, SuperFReaKiN - FLiPCHiP Cal'd for Regular and Premium FueL,
Soon..............
AiRaID FIPK, Expedition Front and Rear Sway Bars, F-1 HooD, P305/75/R17 BFG KO's, 3" Body LiFT
www.tnugent.com/
Old 06-07-2001, 03:53 AM
Vehicle: 2006 Ford F-150
Send a message via AIM to Justinman
Post
I heard that "Flushing" your transmission can cause problems. They will just pump new fluid into your tranny through the cooler lines....They usually don't drop the pan and change the filter. When they flush the tranny it just mixes up all of the tiny metal shavings back into the transmission. I talked to a Ford Service Manager and he said he's seen tranny's fail shortly after a "Flush" and he always drops the pan and drains the TC.
1998 F-150 XLT 4x4 SC 4.6L Auto, Class III hitch, Pioneer Premiere deck, Boston 5x7's, K&N Air filter in stock airbox.
In the near future: New Tires (hopefully 33x12.5) and wheels (need a 5 lug 16.5" for the wild country tires)
Old 06-07-2001, 11:10 PM
Unhappy
where do i start had the flash and took it to a trans shop they started with the trans selector switch found that that was not it then went on to check the wiring so far they are thinking it's the computer.
This has been going on for a week now .
tommorrow we'll see what happings
June 12,2001
just got the truck back with the computer sitting in the engine bay bacause it seems the computer went bad and i can't get another until JULY!!!!!
man this really sucks that I paid allmost $500.00 without any real repairs and they computers ar better then the past
[This message has been edited by ironmaninc (edited 06-12-2001).]
Old 06-08-2001, 12:39 AM
Registered User
Lightbulb
I got the truck with 39k on it,I have changed the fluid once at 45k, and once at 75k and dropped the pan and drained the fluid both times, along with cleaning off the magnet too. I think that I've kept fairly good care of it. Also changed the oil every 45 days, or 3000 miles, still Motorcraft 5w-30.
Also here is a piece of mind, service manager and friend of mine said that the 5.4's with piston slap should stick with a 5w-30 oil to prevent knocking.
Old 06-08-2001, 12:51 AM
Vehicle: 1999 Ford F-150
Post
I had the same exact problem on my Co. truck (1997 F-150 S/C, 4.6L). First time problem occured was @ approx. 124,000 miles. Took to trans. shop @ codes indicated failure of up-flow or down-flow sensors (exhaust). Sensors were contaminated with oil; however, technician could not tell which sensors were defective. That dropped trans. pan & everything was clean. They replaced (4) sensors (up & down-flow) & cured problem. Cost was $427.00. This problem was a result of poorly replaced pan gasket by Ford dealer, when trans. was serviced @ approx. 43,000 miles.
At approx. 155,000 miles the same thing happened. I took truck to independant firm that had former Ford Tech. that diagnosed problem immediately. Problem was trans. oil contamination in one of the exhaust sensor "plug packs". Cost was approx. $115.00. Both times computer codes had to be reset.
1999 Teal Blue F-150 S/C
4.6L, XLT, 3.55 L/S 4x2
Tow pkg., Rhino liner, Engine block heater & Swiss hard toneau cover. Premium sound
255/75 R16 Generals-owl
This" is Mama's pride"
Old 06-13-2001, 10:47 AM
Vehicle: 1997 Ford F-150
Post
I just got home from visiting my friendly FoMoCo dealer's service dept. My complaint was an occasionally flashing OD OFF light (Red '97 F-150 3-door stretch cab 4X4 Off Road with 83,000 miles, babied, not plowed, not towed). Code was still in computer and problem is an intermittant VSS (Variable Speed Sensor)-$10 part, two hours labor to replace).
It's amazing to me that everything started going down the tubes right after hitting 75,000 miles with a 75,000 mile extended warranty--Next time I'll get the 100,000 mile warranty--they haven't ever made a Ford that'll make it to 100,000 without everyting breaking!
I had a '94 Ram 3/4 ton 4X4 before buying the Ford new in '97. The Dodge was a real lemon (I think they all are!!!), but the Ford is catching up with it!!!!! Now that I'm off warranty the doors cracked, but while on warranty (at 72,000 miles), my tranny started acting up and Ford rebuilt it and it cost me nada.
My earlier tranny problem was that it wouldn't stay in OD on a slight highway incline; it kept trying to downshift, but would upshift after a few seconds and kept repeating the cycle every five to ten seconds or so while on the incline. On a steep hill it would downshift and hold okay. They said it was a wrong-sized piston in the torque converter and they put in a new torque converter and rebuilt the rest of the tranny and did it under warranty. Problem went away (for a change).
I guess if I keep it (I want to, it's a great truck), It'll just be one stupid thing after another from now on.
Old 06-13-2001, 03:49 PM
gah gah is offline
Exclamation
Quote:
<font face="Verdana, Arial" size="2">I heard that "Flushing" your transmission can cause problems. They will just pump new fluid into your tranny through the cooler lines....They usually don't drop the pan and change the filter.</font>
Quote:
<font face="Verdana, Arial" size="2">This problem was a result of poorly replaced pan gasket by Ford dealer, when trans. was serviced @ approx. 43,000 miles.</font>
And there you have it. You know what really kills your truck? ..... having someone else work on it. In many ways I think that those hole-in-the-wall mechanic shops do a better job than the Ford service departments because they NEED you to come back and they NEED you to refer others to them.
My experience with service departments at dealerships is that they couldn't give a sh## about your vehicle.
I'd NEVER allow anyone to change my oil, change my ATF or anything else that I can do myself. So far I've only had my truck in for a new seatbelt retractor, passenger mirror, and rear pinion seal. I'm dreading getting a larger radiator installed ... all that Amsoil ATF spilling on the ground. The idiots would probably top off the ATF with Dexron III or similar if they even thought about adding fluid. They're too busy thinking about where they're going to eat lunch.
I read somewhere where one member was able to take the new radiator home and install it himself. Sounds good to me ....
'00 5.4L AUTO 4X4 F-150 Lariat
'98 4.0L 5spd Jeep Wrangler Sport
'02 F-350 PSD CC DRW 6SPD 4X4 Lariat (order this year)
www.hawthorn-engineering.com
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
