F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 06-05-2001, 12:30 PM
Vehicle: 2002 Ford F150
Unhappy Shifter or knob rotating?
I have a little problem. The shift pattern emblem on the top of the shifter knob is moving. It is now pointing so someone looking in the passenger side window can read it. But when I physically try to turn the knob or shifter back it does not appear loose. I am pretty sure that it use to be pointed properly for me to read from driver position. Any ideas? I have a very audible vibration sound when cruising in 5th gear coming from the shifter. This can be quieted by holding the shifter (not practical). I don’t think the emblem itself is loose but could be. I hope the shifter can't unscrew?
2000 F150 XL supercab V6 4.2L 5-spd, 4x2, 3.55 gears, AC, Torreador Red
MODS
  • Line-X bed liner
  • Clarion AM/FM CD head-unit.
  • Ford 10 CD changer out of 94 Probe.
  • Rockford Fosgate 5x7s all around.
  • modified cold air airbox.
  • modified MAF sensor.
  • K&N airfilter.
  • glass pack muffler.
  • tinted windows
  • F150online sticker in back window.
Old 06-05-2001, 03:06 PM
Vehicle: 1999 Ford F150
Send a message via ICQ to bambino
Wink
The little disc that has the shift pattern is known to rotate around a bit. I can tap mine and make a clicking sound that has rattled in the past when the stick vibrates sometimes.
Best thing to do is get a new shift knob! But more practially, the knob itself will pull straight off, don't try to twist, just yank on it. Then you can place it back where you want. I have also done it by just putting the palm of my hand on it, and twisting the way I wanted it adjusted.
As far as the disc rattling, might need to try a dot of epoxy or something. That will prevent it from moving.
hth
Bambino
Bambino Worldwide
Owners Gallery Truck #179
1999 reg cab/short box/ORP/Silver on Dk Graphite - 3.55; 4.6l 5sp; Factory Tonneau; 40 chan CB/Maxrad Antenna; Kicker amp'd sub tubes; Rockford Fosgate components up front; Custom Exhaust; Mobil 1 5w30/Motorcraft FL820s; Amsoil Series 2k in the driveline.
Old 06-05-2001, 04:45 PM
Post
I will give that a try. I had visions of pull 2nd hard one day and having the stick hit the ceiling. Thanks.
MODS
  • Line-X bed liner
  • K&N airfilter.
  • tinted windows
Old 06-05-2001, 08:55 PM
Post
Schmidlapper,
I have the exact same problem. As the previous post suggested, I use the flat of my palm to turn it. Takes a couple rotations to get it moving. What's weird is you can't do it with your fingers and thumbs, just the palm of your hand.
I hope this helps, as it's kind of embarrasing that some members here are capable enough to basically holding my hand through getting a locker, but the only advice I can render is:
1) Hold palm flat
2) Rotate flat palm on shift knob.
Oh well. Let me know if you are having problems with lug nuts or changing your oil. Anything else is above my head.
Regards.
Old 06-05-2001, 09:39 PM
Location: south western NYS Latitude: 42.34 N, Longitude: 78.46 W
Vehicle: 1997 Ford F-150
Send a message via Yahoo to buckdropper
Post
The shift pattern is made to move so the user can adjust it to his or her needs. All you do is place the flat of your thumb on it push down slightly and click it either way until it lands where you want it........................
1997 F-150 XLT 4.6 REGULAR CAB, FLARESIDE PACIFIC CLEARCOAT GREEN 5-SPEED. WESTIN NERF BARS, POWER EVERYTHING,BUG SHIELD, EX-TANG SOFT COVER, BED LINER(FORD).
Better 1/2 : 92 Red T-Bird.
Old 06-06-2001, 12:45 PM
Thumbs up
I got it back in line now. Thanks for the help. Still have the audible vibration noise when in 5th gear and driving around 70 mph. I think its the whole shifter making the noise (resonating). It gets annoying and I crank up the stereo to mask it. Does anyone else have this?
MODS
  • Line-X bed liner
  • K&N airfilter.
  • tinted windows
Old 06-06-2001, 06:54 PM
Vehicle: 2000 Ford F150
Cool
It will get looser over time and start to rattle. On my Ranger I pryed it out of the top of the shifter, put some 2 part epoxy putty in there and put it back in. It never moved after that Just make sure you pry from the back of the shifter.
2000 F150 XLT 4x4 Short Bed. Amazon Green, 5.4L, SuperCab, ORP, Tow Package, Sliding Rear Window, Electronic Shift, Keyless Entry, LT265-70-17 Tires, Clarion Pro Audio, Herculiner Bedliner, Air Silencer Removed.
1994 SVT Mustang Cobra. #1032 of 6009. Black coupe with black leather int., 3.73 rear, Bassani Exhaust, Aluminum D/S, Bridgestone RE-71 255-45-ZR17
My Home Page
Old 06-06-2001, 07:13 PM
Vehicle: 2007 Ford Edge
Smile
I have a slight vibration in the shifter in 5th gear at highway speeds. I haven't thought much of it. The shifter seems to pick up every vibration, like when I run over an expansion joint. The shifter seems loose at time like that. I've driven a lot of different manuals, they all seem to be a little loose. Let the dealer know. If there is some kind of problem, let us know.
Tom
'98 F150 XLT,short bed, STX appearance group, 4.6, 5-speed.
Current mods: K&N air filter, cat back exhaust (Flowmaster 40 w/dual rear side exit), Superchip.
Future mods: short throw shifter, K&N FIPK, lowered suspension, other things seen here!
Old 06-06-2001, 08:58 PM
Post
It looks and feels loose because you are in a cruse (high) gear and there is little tork on the shifter, when its in 4th is is hardly noticable......
Old 06-10-2001, 07:59 PM
Post
For a quick fix, like 200f-150 4x4 stated, just pry the center piece out, be careful not to dent the knob, then I used Testors model cement. It works great, no more vibration or spinning..
1997 F-150 4X4 reg cab long bed.Metalic Teal.
*Ravin 55 dual rear exaust
*Airaid intake
*Billet inserts
*bumper insert
*brush guard
*KC lights
*Superchip
*Delta toolbox
*Tonneau cover
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
